Latest: tbafonso
Overall: 17130
Online Now [113]:
Visitors: 113
Today: 41123
Total: 104622872
Forums › The Car › 206 Problems › Squeaking noise, from cold start
BobT
PostPosted: Thu Sep 26, 2013 8:14 am Up
I've got a weird squeaking noise coming from my car when I start it cold, that goes away after 5 minutes or so driving (presumably warmer).
It happens when I use the accelerator and sometimes the clutch and sounds a bit like a rusty spring with no lubrication, or something. Only happens when I'm in gear, i.e. can push the accelerator, clutch and so on around without making the noise when I'm in neutral or stationary. If I push the accelerator down with the clutch in, I don't get the squeak. It's quite loud at first but goes away after a while.
I'm at a loss to work out where it's coming from or what's causing it.
Anyone have any clue?
BobT
PostPosted: Thu Sep 26, 2013 8:34 am Up
Oh...
Uncovered a possible here:
www.206info.co.uk/Foru...queak.html
It started happening after I got my exhaust "fixed" actually.
Razor34
PostPosted: Fri Sep 27, 2013 9:23 am Up
Hi,
It is the join between the front pipe and remainder. I have got the flexi spring parts from Peugeot and going to fit mine tomorrow as I have the same issue and will copper grease all around it to ensure this no longer happens. Parts are about £13.00
Ray
Razor34
PostPosted: Tue Oct 01, 2013 8:47 am Up
Changed part over and copper greased up. Voila noise has gone!!!!
Ray
BobT
PostPosted: Fri Oct 25, 2013 5:04 am Up
Sorry, missed this. Thanks for the tip Smile
Razor34
PostPosted: Fri Oct 25, 2013 6:54 am Up
Not a problem, hope it works for you.
Ray
