Latest: lio94
Overall: 17181
Online Now [412]:
Visitors: 411
Today: 68304
Total: 141623661
Forums › The Car › 206 Talk › Catalytic converter
Catalytic converter
Seatock789
PostPosted: Tue Sep 24, 2013 10:02 am Up
Hi all,
Was driving home happily the other day when I heard the exhaust getting louder, here we go I thought, a hole to patch up, turning the corner a loud clang and the whole exhaust fell off, luckily i wasn't going too fast. After looking at it, the coller from the cat had rusted through. I've now ordered a new one from react at £86 along with a new link pipe that wasn't looking to good either for £10.
Hopefully if the weather holds up this weekend I will be attempting to replace the parts then, for now it's all held together with wire, exhaust paste & quicksteel.
My only fear is the nuts holding the cat to the manifold, apart from soaking them in penetrating oil, any one have any other tips?
ollyshep206
PostPosted: Tue Sep 24, 2013 12:11 pm Up
Exact same thing happened to me 2 days ago. Heading down the e mechanics to ask them to weld it back on for me instead of buying a new one.
If in doubt, flat out.
Seatock789
PostPosted: Tue Sep 24, 2013 12:35 pm Up
I did think about that but decided for piece of mind to replace it, I'll cash in the old one at a recycling place and see what it's worth.
PostPosted: Tue Sep 24, 2013 12:48 pm Up
well you done the right thing to replace it,as a new CAT is good for your car,and you won't worry about it anymore,so you have to be very careful with the bolts holding the cat with the manifold,if any bolt snap,it will be a problem,but nothing that can't be fixed,but will be costly.
Seatock789
PostPosted: Wed Sep 25, 2013 10:08 am Up
I've got a full set of drill bits at the ready....lol
PostPosted: Wed Sep 25, 2013 3:58 pm Up
Be warned a cat at that price will fail in under a year. Some have rumored to be a mear 2 months!
benny180
PostPosted: Thu Sep 26, 2013 10:24 am Up
when I had get a new CAT for my 180 it set me back £259!!!
Seatock789
PostPosted: Thu Sep 26, 2013 1:56 pm Up
It's got a 2 year guarantee with it from React (Same as eurocarparts) so if it does fail, it will be going straight back.
Tomorrows the day, providing the weather holds out, i've sprayed the bolts all week, got myself a decent 13mm socket and a long extension bar attached to a breaker bar, hopefully it'll come apart without too many skinned knuckles.
Seatock789
PostPosted: Sun Sep 29, 2013 11:15 am Up
Finally done and completely air tight, although I did have to take it apart a 2nd time to put some proper exhaust sealant on it.
Only problem encountered was i nearly rounded 2 bolts on the manifold to cat, trusty 1/2 inch socket hammered on and they where off in a jiffy.
All this done on the driveway with the car up on 2 bricks.
Drop links next, clunking sound coming from the front end and they look decidedly dodgy.
