Latest: Stu-mill
Overall: 17131
Online Now [40]:
Visitors: 39
Today: 9758
Total: 104897388
Forums › The Car › 206 Problems › rear back lights
rear back lights
bilsy
PostPosted: Mon Sep 30, 2013 1:10 am Up
The problem is my back lights are out and I can't find were the fuse is my fuse box is under the steering wheel and one in engine all other lights work brake fine reverse fine indicators fine put new bulbs in still nothing can anybody help me please
bilsy
PostPosted: Mon Sep 30, 2013 1:12 am Up
onHelp with fusebox
PostPosted: Mon Sep 30, 2013 7:23 am Up
Links to both the pre-plex and multi-plex fuse locations can be found here
PostPosted: Mon Sep 30, 2013 11:56 am Up
Bad earth....to go with the bad English.
bilsy
PostPosted: Mon Sep 30, 2013 2:04 pm Up
. Checked the earth there fine
bilsy
PostPosted: Mon Sep 30, 2013 2:08 pm Up
How many fuse boxes are there I have one under steering wheel and one in engine is there another one somewre
PostPosted: Mon Sep 30, 2013 2:37 pm Up
Check for corroded terminals in the bulb holders themselves.
bilsy
PostPosted: Mon Sep 30, 2013 2:55 pm Up
Will do that tomorrow but is there two or three fuse boxes
PostPosted: Mon Sep 30, 2013 2:56 pm Up
2 as far as I know. & I'd try another tail light unit to check for sure.
bilsy
PostPosted: Mon Sep 30, 2013 3:00 pm Up
Was thinking it might be the unit cheers for you're help
PostPosted: Mon Sep 30, 2013 3:55 pm Up
Your welcome welcome welcome
PostPosted: Tue Oct 01, 2013 12:33 pm Up
You say you have checked earth. How exactly, step by step did you do that
Have you checked that there is not +12v at the bulb holder when lights are switched on? If so how exactly did you do that?
A lot of people have volt meters but don't know the simple traps that untrained use mean you fall into and the false diagnosis that can cause. Tell me, step by step how you have done the test.
bilsy
PostPosted: Tue Oct 01, 2013 1:11 pm Up
. Can u give me the step by step way to do this please
DREWDEN
PostPosted: Tue Oct 01, 2013 1:37 pm Up
Hi bilsy, what engine, and year is your car, (multiplex or preplex) reason i ask is my car, tail and front side lights do not have a fuse as such, in that it can blow something in the engine bsi a resister i think, as a auto elec had to sort my bsi out, was looking for fuses for ages without sucess.
Are your front sidelights working ok.
206 2ltr Hdi glx 53 plate
bilsy
PostPosted: Tue Oct 01, 2013 2:13 pm Up
No they are not it all started when I changed front headlight bulb at the time 2 back lightswere out as wwell the car is a 206. SE on a 54 plate
