Latest: tebas93089
Overall: 17179
Online Now [116]:
Visitors: 116
Today: 26523
Total: 138546143
Forums › The Car › 206 Problems › Air Noise when brakes released
aidan117
PostPosted: Mon Oct 07, 2013 6:34 am Up
Hi Guys,
Gotta little problem on my 52 plate 1.1 it started about a week ago when i noticed when i released the brakes i heard a kind of air noise coming from the footwell of passenger side, sometimes it lasts when accelerating but only for a few secs before fading out. But the noise stops completely when pressing the brake pedal but does it again when the brake pedal is released doesn't happen all the time but most times.
Any ideas on what it is and if its expensive to fix?
Cheers
Mr-Tigger
PostPosted: Mon Oct 07, 2013 6:43 am Up
brake servo 99%, could just be a damaged pipe but not likely. servo is give or take 100 new,fitting,depends how clever you are but not a novice job
gazza82
That would be the brake servo ... releasing the vacuum it has built up to help apply the brakes.
Don't think it's normal to hiss unless you push the pedal with the engine off so it could be the pipe from the engine or an internal seal ... Sad
Mr-Tigger
PostPosted: Mon Oct 07, 2013 6:59 am Up
no it shouldnt leak. test the servo by:
engine/key off,pump the pedal till it goes hard,then holding the brake pedal gently turn the engine on it should slowly fall to normal braking position
also when it hisses if it stops,or stops then starts again when u tap the pedal its definately the servo
iainlovatt
PostPosted: Mon Oct 07, 2013 7:56 am Up
brake servo.
(My Garage)
aidan117
PostPosted: Mon Oct 07, 2013 8:05 pm Up
So im guessing its the brake servo then..hah, cheers guys thanks for help
aidan117
PostPosted: Tue Oct 08, 2013 6:49 am Up
