Latest: Beduff1977
Overall: 17134
Online Now [1801]:
Visitors: 1800
Today: 227035
Total: 109793425
Forums › The Car › 206 Problems › Power Steering Pump Socket???
tom01
PostPosted: Thu Oct 10, 2013 3:27 am Up
Looking to remove the power steering pump. It says on haynes that I need a special socket for the union nut and the part number is 0720E. So I rang parts department today and apparently they don't sell anything like it 0_o
Any ideas?
Zack
PostPosted: Thu Oct 10, 2013 3:40 am Up
spanner thats what i use. on gti.
cheers
tom01
PostPosted: Thu Oct 10, 2013 3:44 am Up
Flare spanner? How was access?
Zack
PostPosted: Thu Oct 10, 2013 3:46 am Up
you got any pictures?
tom01
PostPosted: Thu Oct 10, 2013 3:55 am Up
Zack
PostPosted: Thu Oct 10, 2013 3:56 am Up
Never had that roller/pulley off. sorry
tom01
PostPosted: Thu Oct 10, 2013 3:59 am Up
Apparently it's for the mounting bolt. Just want to swap a pump I've got from the scrapper!
Zack
PostPosted: Thu Oct 10, 2013 4:01 am Up
If you changing the whole unit you don't need to take that wheel off. There's a couple Allen key bouts behind that.
gazza82
PostPosted: Thu Oct 10, 2013 4:32 am Up
That's where the socket is fitted .. the pic isn't great but it's not in the pulley centre .. it goes through the holes!
I think OP means the feed pipe ... there isn't much room and it probably was pic 22.4 he should have posted! It looks a bit like a brake pipe spanner although much larger than any I have.
Zack
PostPosted: Thu Oct 10, 2013 5:05 am Up
i used a normal allen key
PostPosted: Thu Oct 10, 2013 3:06 pm Up
Normal Allen key does the job
