Online Now [560]:
Visitors: 559
Today: 68212
Total: 105645167
Forums › The Car › 206 Talk › Suspension Parts-service box?
Triggerfish
PostPosted: Fri Oct 11, 2013 12:13 pm Up
Can anyone post an image of the parts showing the suspension to include the followings:
1. Shock absorber with top & bottom mounts, nuts etc.
2. Springs.
3. anti drop link.
4. ARB.
Thanks in advance.
206: 1.1L, 2002.
PostPosted: Fri Oct 11, 2013 12:59 pm Up
VIN please.
Triggerfish
PostPosted: Fri Oct 11, 2013 2:41 pm Up
V9977 wrote:
VIN please.
VF32AHFXF42669443
206: 1.1L, 2002.
PostPosted: Fri Oct 11, 2013 10:37 pm Up
By-your-command:
Triggerfish
PostPosted: Sat Oct 12, 2013 4:06 am Up
Thank you very much V9977!.....very useful.
I take it only professionals can access this service box thing?
206: 1.1L, 2002.
Lecktorious
PostPosted: Sat Oct 12, 2013 4:08 am Up
Trade Rating: +59
Anyone that has an email address can.
'98 Nile Blue 306 GTi 6
PostPosted: Sat Oct 12, 2013 4:27 am Up
The only thing I'd get from the dealer from that list is nut and bolts, springs and the anti roll bar.
Triggerfish
PostPosted: Sat Oct 12, 2013 6:36 am Up
ok guys, before I go any further on this, what do you guys think?
The ARB is usually angled downwards when the car is in order. My ARB is currently level (both sides) with the lower control arm. Am assuming it is my shocks that are gone? The springs appears to be ok, no cracks. I noticed I can feel the bumps on the roads a lot more noticeable now.....so am I correct?
206: 1.1L, 2002.
PostPosted: Sat Oct 12, 2013 6:56 am Up
ARB is level when the car is on the ground. If the dampers were gone in any way it wouldn't change the way the car sits.
Triggerfish
PostPosted: Sat Oct 12, 2013 7:55 am Up
That's interesting on the ARB, this can't be right can it?.....my car's ARB (when looking at it from the road wheel-side view) the ARB is somewhat angled around 30 degrees downwards (from bushes end towards drop link).....this is what had always been.....and the control arm is also angled downwards.....This is what I would consider NORMAL.
But now, the ARB is in line with the control arm (horizontal), meaning it is level with the inner control arm bushes, this also means the car is also lower than normal. The control arm is also level (horizontal-2 bushes are level with ball joint end)
So what could that be?.....checked the ARB and no cracks visually anyway?
206: 1.1L, 2002.
Triggerfish
PostPosted: Sat Oct 12, 2013 6:27 pm Up
So is it possible to join service box and check out detail information on parts and part numbers....is it free?
Is it also possible to order parts directly from service box?
206: 1.1L, 2002.
