Posted: Fri Oct 11, 2013 6:24 am |
Looking to replace the following parts with as much original/OEM product brands as possible.
Can anyone list the original branded parts?
Spark Plugs
Air Filter
Oil Filter - Purflux
Full Synthetic Oil
Timing Belt - Dayco or Gates
Brake pads
Water pump
H7/H4/W5W/P21W lights
Pollen cabin filter
Any info or recommendations would be much appreciated.
If there is an online store on where I can buy these parts that would be very useful also ![Smile Smile](images/smiles/icon_smile.gif)
Cheers
| | ![](images/spacer.gif) |
Posted: Fri Oct 11, 2013 9:19 am |
To do so, reg/chassis number or engine size would be required. I could do it for you now if you wish
Posted: Fri Oct 11, 2013 1:05 pm |
Don't know the codes (though I should).
Brands are as follows:
Sparking plugs: Eyquem
Engine Oil: Total
Timing belt: Gates
Brake pads: front Mintex, rear Bosch/Lucas
Bulbs: Osram
I would go to Peugeot dealer with the VIN and finish with it.
It will be fine if you get just the parts from them and do the work yourself or local garage to keep labor costs realistic.
Posted: Fri Oct 11, 2013 3:23 pm |
Where abouts are you?i work for pug and can do the parts at a reasonable price
Posted: Fri Oct 11, 2013 4:12 pm |
You've got a low post count dicko79 so shouldn't really be selling what with the latest going ons
Posted: Fri Oct 11, 2013 6:34 pm |
hayes_ctfc wrote: |
To do so, reg/chassis number or engine size would be required. I could do it for you now if you wish |
I'm from Australia but would appreciate any assistance.
Posted: Sat Oct 12, 2013 1:39 am |
cheekyage wrote: |
hayes_ctfc wrote: |
I'm from Australia but would appreciate any assistance. |
Well, technically I'm the closest one to you.
