Online Now [1376]:
Visitors: 1375
Today: 39051
Total: 106376302
Forums › The Car › 206 Problems › Oil leak on GTi 180
Oil leak on GTi 180
cheekyage
PostPosted: Sun Oct 13, 2013 1:39 am Up
Hi all,
As I drove out of my garage I noticed a tiny oil drop on the floor.
After looking underneath the car I could see some residue and another drip hanging on the passenger (left hand side), closer to the front wheel.
I have attached a photo to help explain my scenario.
Does anyone know where this is coming from or what it could be?
PostPosted: Sun Oct 13, 2013 2:45 am Up
It might be power steering being on that side of the car, I had an oil leak on mine but was more central and turned out to be the rocker cover gasket had gone
cheekyage
PostPosted: Sun Oct 13, 2013 2:57 am Up
Post updated - have mentioned it is on the passenger LEFT hand side.
PostPosted: Sun Oct 13, 2013 3:06 am Up
As that is under the subframe, it could be coming from anywhere,
PostPosted: Sun Oct 13, 2013 4:51 am Up
Looks like oil is getting into the subframe somewhere else. Could be from anywhere.
ukskater01
PostPosted: Sun Oct 13, 2013 6:58 am Up
I had oil from the gearbox when the driveshaft seals went.
