Latest: tbafonso
Overall: 17130
Online Now [285]:
Visitors: 284
Today: 2187
Total: 102578132
Forums › The Car › 206 Talk › phase 2 boot trim spraying
Geforce
PostPosted: Thu Oct 17, 2013 10:20 am Up
Im about to buy a phase 2 boot trim however its the wrong shade of silver so I want to spray it myself, is it a case of a light sand down,spray colour,then clear lactor?
Cheers
gazza82
PostPosted: Thu Oct 17, 2013 11:28 am Up
Yes, unless you go down to the plastic, then you will need plastic primer.
Use fine wet&dry and wet it to rub down ...
Geforce
PostPosted: Thu Oct 17, 2013 2:39 pm Up
Thanks, with it being a darker silver and needs spraying a lighter shade, that shouldn't be a problem should it, in terms of making it even darker when spraying it my colour.
gazza82
PostPosted: Fri Oct 18, 2013 6:13 am Up
Not if you give it enough coats.
