Latest: lio94
Overall: 17181
Online Now [336]:
Visitors: 335
Today: 47485
Total: 141486479
Forums › The Car › 206 Problems › Rear Wiper
Rear Wiper
Austin
PostPosted: Wed Oct 23, 2013 3:46 pm Up
Intermittent fault with my rear wiper... Twist stalk to turn on, sometimes it will come on and other times I just hear a clicking noise by the steering wheel, but doesn't work. If I turn it off and on again then it works. I think it's the relay but not 100%, anyone else had this problem? Also where abouts is the relay located?
Cheers
Austin
PostPosted: Wed Oct 23, 2013 5:46 pm Up
Possibly the com2000 on the way out
iainlovatt
PostPosted: Thu Oct 24, 2013 8:16 am Up
What He Said
(My Garage)
Austin
PostPosted: Thu Oct 24, 2013 9:12 am Up
Great! Would explain why my indicator and headlights play up aswell. What comm unit am I looking for? Is there different types? Car is 2004 1.4 fever, multi-plexed.
Daniel1994
PostPosted: Tue Oct 29, 2013 9:26 am Up
My rear wiper has packed up completely but everything else works fine, I assumed rear wiper motor but could I be wrong?
DREWDEN
PostPosted: Tue Oct 29, 2013 9:52 am Up
Rear wipers work of a 15amp fuse, Yours could be just the fuse, have you checked it.
206 2ltr Hdi glx 53 plate
Daniel1994
PostPosted: Tue Oct 29, 2013 2:02 pm Up
I'll check it tomorrow and see, which fuse box is it? Under bonnet or under drivers steering wheel
mattymj
PostPosted: Tue Oct 29, 2013 2:24 pm Up
Open your boot and take off the cover on the inside. Disconnect the plug going to the wiper motor then see if the relay clicks as it should. Mine did so I suspected the electrics on the wiper was faulty.
PostPosted: Tue Oct 29, 2013 2:25 pm Up
Fuse 11 in the passenger compartment fusebox
Daniel1994
PostPosted: Tue Oct 29, 2013 2:33 pm Up
Cheers guys, great advice as usual Ill try both these methods tomorrow if the fuse intact Smile
