Online Now [86]:
Visitors: 86
Today: 22953
Total: 138591481
Forums › The Car › 206 Problems › 1st & 2nd hard to get into gear
BobT
PostPosted: Fri Oct 25, 2013 4:00 am Up
I'm finding it increasingly hard to get 1st and 2nd gear with my 206 (it's an 03).
2nd has always been quite "hard" but this morning I pulled up at a roundabout on the A10 and couldn't find either 1st or 2nd, i.e. the usual position for them was just loose as hell and drive not engaged. I managed to pull away in 3rd really slowly.
I made it to a car park and played around a bit. Managed to "find" them again and satisfied myself it was OK enough to get me to work. Still quite a bit of force needed to get 2nd and 1st to an extent.
Any tips? (Buy a new car is what I was thinking - expensive option).
DREWDEN
PostPosted: Fri Oct 25, 2013 2:31 pm Up
Cable or hydraulic, how long has the clutch been in.
206 2ltr Hdi glx 53 plate
pug206lx
PostPosted: Sat Oct 26, 2013 11:00 am Up
Possible issue with linkage rods if it's not cable. Could also be that the wrong oil has been put in in the past but i doubt it as its normally just stiff and notchy if that's the case.
