Latest: ArtistKS
Overall: 17145
Online Now [86]:
Visitors: 85
Today: 5009
Total: 116038813
Forums › The Car › 206 Problems › Aerosol Can not right paint
Geforce
PostPosted: Sat Oct 26, 2013 1:01 pm Up
Ive just brought a aerosol can with paint code EYC but its to dark for my car which is EYC, can anyone recommend somewhere where the paint is a half decent match
Cheers
Lowiee
PostPosted: Sat Oct 26, 2013 1:06 pm Up
have you tried Paint-Body-Shop-Supplies in your local area usually they can use paint chips to define your closest colour match and supply even in aerosol form
doski
PostPosted: Sat Oct 26, 2013 1:53 pm Up
there's a place near me not sure if they are nationwide called NRP they age the paint and use this little electronic scanner thing to match the paint. good luck
Geforce
PostPosted: Sat Oct 26, 2013 2:29 pm Up
I would prefer to buy online, surely people on here has brought paint online that is a good match
PostPosted: Sat Oct 26, 2013 2:37 pm Up
www.206info.co.uk/Gara...d=127.html
Give them all the vehicle details and send them a decent photo of the colour your after and they should be able to get it spot on.
Did you get the paint code from the sticker attached to the B post? Might be worth checking on service box characteristics to make sure the information is right.
Geforce
PostPosted: Sat Oct 26, 2013 6:42 pm Up
macca1411 wrote:
http://www.206info.co.uk/Garage/mode=biz_details/biz_id=127.html
i got the paint code from under the bonet and its on the right hand side.
20Drift
PostPosted: Sat Oct 26, 2013 6:56 pm Up
Did you properly shake the can, and let the paint dry fully?
Geforce
PostPosted: Sat Oct 26, 2013 7:14 pm Up
Yes its dry now and still to dark , maybe i should give it a 2nd coat.
PostPosted: Sun Oct 27, 2013 2:16 am Up
You must have an early 206 then. You might find that you have the right colour, it's just your paint has faded over the last 13 years.
I'd still double check the VIN on servicebox just to make sure a previous owner hasn't dicked about with the sticker to make the car more saleable.
I'd also check the can and make sure someone hasn't been swapping caps about in the shop.
Geforce
PostPosted: Sun Oct 27, 2013 6:15 am Up
i have a 2000 model, i know its EYC because ive brought EYC parts before and its been a perfect match.
So if my paint has faded how will i get a good match from anyone?
omega
PostPosted: Sun Oct 27, 2013 8:01 am Up
So if my paint has faded how will i get a good match from anyone?[/quote]
this is where you need lots of skill and why body shops charge lots of money
what panel are you painting?
1245678
Geforce
PostPosted: Sun Oct 27, 2013 9:42 am Up
what panel are you painting?[/quote]
Trying to spray a phase 2 boot trim.
johnboy
PostPosted: Sun Oct 27, 2013 2:31 pm Up
i've always used these www.paints4u.com/
