Latest: Beduff1977
Overall: 17134
Online Now [500]:
Visitors: 499
Today: 70851
Total: 107176204
Forums › The Car › 206 Problems › Front bumper removal
bashyy1
PostPosted: Sat Nov 02, 2013 2:19 pm Up
So I had a go at taking the bumper off today to fit my sp grill as I heard it was supposed to be easier.
I was pretty close to getting it off, the only problem I had was with the one bolt either side of the bumper, they will just not undo, it just spins around and around. (heard this is common)
Anyone ever done had this and can lend a hand?
Heard you just cut it off but I don't see how I'll have to room to get a saw in there, plus I'll risk damaging my paint.
Aegean Blue Gti 180.
Project Thread
PostPosted: Sat Nov 02, 2013 2:27 pm Up
I had the same on my old gti, is it the bolts which secure it to the front wings? If so, I found it easier to remove the headlights and undone the bolts from there
bashyy1
PostPosted: Sat Nov 02, 2013 2:38 pm Up
Yeah its them bolts mate, it's not a problem actually getting to the bolt I can get to it, but then when I try to undo the nut/bolt on the screw it just spins the whole screw around. Sad
Project Thread
robb
PostPosted: Sat Nov 02, 2013 2:49 pm Up
I actually had this problem on both sides today, it's a poor design as the nuts will get seized and have much stronger hold with rust to the thread than the silly plastic sliders on the bumper do.
I struggled with the car on a lift, but eventually managed to get some vice grips into the squares and used my ratchet spanner on the nut, was still very difficult, but eventually got it sorted.
To install again I just used a nut and bolt with some nice big washers either side, so next time I can get a pair of spanners on the job and don't have the rely on the silly bumper plastic clips, as with most things like that they are great for 2 to 3 years but cause major issue later down the line
PostPosted: Sat Nov 02, 2013 2:53 pm Up
Like Robb said, get some vice grips or if you got a mate free, get them to hold the nut while you undo the bolt, thats what me and my brother did
bashyy1
PostPosted: Sat Nov 02, 2013 3:21 pm Up
Yeah!!That's exactly what I was trying to say, the sliders just can't hack it and break, hense the screw spinning.
I just couldn't explain how you did haha.
And funnily enough I did try using a vice grip on the square bit, I guess I'll try again now I've put it all back together haha.
So is it easier to get to these bolts taking the headlights out do we think?
Thanks for the quick replies guys btw
Project Thread
iainlovatt
PostPosted: Sat Nov 02, 2013 3:27 pm Up
remove the headlights.
Unfortunately they are security type bolts. Absolute night mare,,
Best bid of advice, either break the bolt or get some mole grips on it and then try undoing it.
(My Garage)
PezHdi
PostPosted: Sat Nov 02, 2013 3:46 pm Up
Smash them out and make your own with a washer set up Smile use copper grease on them so if you take it off again it will be a piece of cake Smile
EXL Pez
bashyy1
PostPosted: Sat Nov 02, 2013 3:49 pm Up
Thanks a lot guys, appreciate it!!!
Project Thread
bashyy1
PostPosted: Sun Nov 03, 2013 10:30 am Up
Finally - All done and complete today
Buzzin!
Project Thread
