Online Now [148]:
Visitors: 147
Today: 7046
Total: 138686378
Forums › The Car › 206 Problems › 206 1.1 52 plate non start, wipers and indicators problems
gibbo300
PostPosted: Sun Nov 03, 2013 12:51 pm Up
hi new to the forum so greetings to all.
a lady i know has probs with her 206.
1. sometimes when she turns the ignition off after a journey it will not restart. if left for about half an hour it then starts.
2. the wipers come on sometimes for no reason,even when it is sunny outside.
3. the indicators stop working completely.
all problems are random and intermittent, any ideas and would they all be related?
thanks in advance
iainlovatt
PostPosted: Sun Nov 03, 2013 12:57 pm Up
start off by changing the comm unit, That should fix the indicator and wiper issue.
Other issue sounds like an immobilizer issue..
(My Garage)
gibbo300
PostPosted: Sun Nov 03, 2013 4:11 pm Up
thanks Iain, can you tell me where the obd socket is on these cars?
PostPosted: Sun Nov 03, 2013 4:26 pm Up
Just behind the fuse box panel to the right of the drivers knee.
gibbo300
PostPosted: Mon Nov 04, 2013 8:42 am Up
thanks for that Macca
DREWDEN
PostPosted: Mon Nov 04, 2013 10:07 am Up
The starting issue could be the starter motor, the brushes inside can stick when hot, then when left to cool down can free up again.
Next time it does it try tapping the starter motor a few times and see if it frees up the brushes, if that works then you know its the starter motor.
206 2ltr Hdi glx 53 plate
gibbo300
PostPosted: Wed Nov 06, 2013 11:14 am Up
thanks Drewden, will give it a try
