Posted: Thu Nov 07, 2013 5:13 pm |
Posted: Fri Nov 08, 2013 4:05 am |
Why? You have one already
| Team Impossible Possible
Posted: Fri Nov 08, 2013 5:16 am |
What's have one with launch control do I????
Posted: Fri Nov 08, 2013 7:12 am |
Launch control on a 206? really?
Posted: Fri Nov 08, 2013 5:49 pm |
All I want to know is if it will fit?
Posted: Sat Nov 09, 2013 2:22 am |
waste of money imo no traction controll etc so all its going to do is hold the revs which your foot can do
Posted: Sat Nov 09, 2013 3:37 am |
Why have one? The car has one set about 6.5k rpm anyway...
