Online Now [89]:
Visitors: 88
Today: 33520
Total: 138823874
Forums › The Car › 206 Problems › 53 plate 206 airbag ecu error
skeeters
PostPosted: Fri Nov 08, 2013 2:53 pm Up
Hi, this is my first time posting so i hope you cut me a bit of latitude here. I had a bump front end, no airbags went off, the seat belt tensioners didnt either. It was a slow speed bump, bent front though, had repaired but drivers airbag light was on, diagnostic showed no error codes but solid airbag light. Decided to send ecu away to clear any crash data, put back in now have both airbag lights on. Got diagnostic put back on now getting no codes just unknown error. I am at a loss now only thing I can think of is to get secondhand ecu of same model and hope it goes out. I was wondering if anyone had any suggestions.
PostPosted: Fri Nov 08, 2013 3:02 pm Up
Not sure if you need to re-associate the airbag ECU using PP2000. I know you do when you change the ECU, so guessing you will when you have had the info on the ECU cleared.
skeeters
PostPosted: Fri Nov 08, 2013 3:14 pm Up
Thanks for the advice, where will i find someone with a pp2000 to do this.
PostPosted: Fri Nov 08, 2013 3:16 pm Up
www.206info.co.uk/Foru...c/t=55053/
There are more members with it, they just haven't added their details to the map.
skeeters
PostPosted: Fri Nov 08, 2013 3:59 pm Up
Many thanks for the help, I had a look at the map, I have one problem though I am in scotland no members here with pp2000. So dont know, very annoying I have been trying to get this car back on road sinc e July now. It runs fine but cant tax it because I need vic check, and cant do that with airbag light on. I Cant use a garage because I am unemployed so have limited options but need car now. Maybe I just change the parts until it is fixed gradually with used parts. Again thanks anyways..
