Latest: jackrox1992
Overall: 17186
Online Now [502]:
Visitors: 501
Today: 7560
Total: 148548859
Forums › The Car › 206 Problems › 206 2.0 HDi - Ignition Turning Issues
jackwetson
PostPosted: Wed Nov 13, 2013 10:31 am Up
Hi There,
I'm experiencing an odd problem with my pug out of the blue.
Turning the key threw positions one and two is fine, but turning it into the 3rd position (start the engine) is very stiff and it sometimes gets stuck beyond position 3 and the engine makes a horrible "grinding" sounds.
Just wondering if anyone has any idea what might cause it to be sticking?
Diagbox available for use in Stroud, Gloucestershire.
PostPosted: Wed Nov 13, 2013 10:42 am Up
May need a new ignition barrel. Easier and cheaper to change all the locks.
The grinding noise is the starter motor staying in position because key is sticking. An easy way to wear the teeth down on either the starter or the more expensive flywheel, which could cause issues later with the teeth failing to mesh properly.
jackwetson
PostPosted: Wed Nov 13, 2013 10:44 am Up
I thought this may be the case, i've read in places about knocking the barrel with a pinhammer as it may be jammed. Any truth in this? And dont worry, im not sitting their letting it grind Smile
DREWDEN
PostPosted: Wed Nov 13, 2013 10:55 am Up
Disconnect the battery, and try messing about with it, try lubricating the key with electrical contact cleaner. or spraying directly up the barrel, see if that frees it up.
206 2ltr Hdi glx 53 plate
PostPosted: Wed Nov 13, 2013 3:01 pm Up
Drewden +1. Then, if that makes it work correctly, follow that with a small squirt of silicone grease.
