Latest: Kifi69
Overall: 17183
Online Now [672]:
Visitors: 671
Today: 85308
Total: 143925300
Forums › The Car › 206 Problems › Two questions..cambelt and boot lock!
RockRulz
PostPosted: Wed Nov 13, 2013 9:14 pm Up
Hi guys.
Is there a way of telling if my cam belt needs changing. I've got no history on my 206 and it's done 93000 miles. Is it possible to tell the age/condition of the belt?
My boot does not always lock with the central locking and as there is no manual key lock on it....the car is unsecure. I have had to fiddle about with it until it did finally lock, then I climbed through the back seat and undid the connector so the boot is permanently locked fir now.
Any suggestions/advice greatly appreciated thanks Smile
www.facebook.com/Hazel...rington151
Tolkienfan001
PostPosted: Thu Nov 14, 2013 12:07 am Up
Trade Rating: +13
Better to be safe than sorry just change the belt and water pump.
2005 1.4 16v Sport
Check out my 206 here!
bistoo09
PostPosted: Thu Nov 14, 2013 3:24 am Up
Change the belt asap. Mine went at 80k.
Peugeot 206 1.1LX Silver
Carbon Wrapped Front Badge
White 15" Cyclones
"Ride or Die" - Brian O'Connor (Paul Walker)
iainlovatt
PostPosted: Thu Nov 14, 2013 3:50 am Up
All we ever here is cambelt failure, So if i were you, i would have it changed, other wise you run the risk of blowing up your engine!
(My Garage)
southwestchap
PostPosted: Thu Nov 14, 2013 5:41 am Up
you can tell if it really wore. Whip the cambelt covers off and see if any of the writing is still visible. Have you got a petrol? the belts aren't very wide and will be weaker when wore.
DREWDEN
PostPosted: Thu Nov 14, 2013 8:25 am Up
You could go on the gov uk site. www.gov.uk/check-mot-h...ry-vehicle
This tells you the full MOT history of the car from new, gives the test station name and tele no.
Maybe the previous owner- owners had a pattern of the same testing station and they did all the work on the car,
a quick phone call, and they should tell you.
206 2ltr Hdi glx 53 plate
gazza82
PostPosted: Thu Nov 14, 2013 10:54 am Up
Boot lock is probably the solenoid that operates it. Its a quick swap over or it may be that the operating rod is starting to bend .. it's plastic and no longer pushing/pulling the lock mechanism.
Can you hear anything when you press the key fob to lock/unlock from the tailgate?
RockRulz
PostPosted: Thu Nov 14, 2013 5:55 pm Up
Re the cambelt....it's being done on Tuesday, along with water pump. As you all said...better to be safe than sorry.
Gazza....the boot lock rod works fine...it's the relay/solenoid I bet. When you activate the central locking most times there is no noise from the boot mechanism.....once ever so often it does click.
gazza82
PostPosted: Fri Nov 15, 2013 5:19 am Up
Might even be loose connection ... take the hatchback lining off (pull gently but firmly) and you can see the lock and solenoid. Try unplugging/replugging first ... then it will be replacing the solenoid unit (two screws).
RockRulz
PostPosted: Fri Nov 15, 2013 5:57 pm Up
I've already unplugged done all that. Think its a new unit I need.
