Latest: lio94
Overall: 17181
Online Now [268]:
Visitors: 267
Today: 16535
Total: 141883700
Forums › The Car › 206 Problems › clutch problem
clutch problem
donnypaul81
PostPosted: Thu Nov 21, 2013 3:52 am Up
My mum has a 206 1.4 petrol estate the clutch sometimes doesn't work at all then it does work there's no grinding slipping etc it's done it 4 times in the last week the peddle seems fine not high biting or low biting everything seems ok but like a say it just goes and then won't go into gear till it's turned off and then back on again ? Ive searched the net and not found any thing so last resort to come on here and ask
mattymj
PostPosted: Thu Nov 21, 2013 9:13 am Up
Is it hydraulic or cable? May need bleeding if hydraulic
PostPosted: Thu Nov 21, 2013 12:28 pm Up
What does the pedal feel like when the clutch isn't working?
Same as normal, slightly more easy to press or really sloppy?
