Online Now [1246]:
Visitors: 1245
Today: 198801
Total: 149266923
Forums › Welcome › Frequently Asked Questions (FAQ) › Oil advice and recommendations
Forum Index › Frequently Asked Questions (FAQ)
oilman
PostPosted: Mon Sep 10, 2012 3:39 am Up
Shell Helix Ultra 5w-40 is a good oil for the money. It meets lots of manufacturer specs and gives a good level of protection. It's not the very best, but not the most expensive either.
Cheers
Tim
Use the code 206I and get 10% Club Discount
View Opie Oils Current Offers Here > >
oilman's website: www.opieoils.co.uk/ - register for news and offers
email: sales@opieoils.co.uk
phone: 01209 202944
PostPosted: Wed Sep 12, 2012 9:50 am Up
Cheers for reply Tim.
We have quite adverse conditions here in the summer, with extreme heat in the middle of the city, and slow as well as v.high speeds/loads.
This leads to people really discussing about engine&gearbox oils on all makes of car etc.
I have experienced a massive difference with that oil like alot of people who mainly use 5W30 or 5W40 full-syn Helix Ultra. It is considered mid to high priced but the effects of using it on economy/reliability more than justifies the cost is the thinking.
The only other oil regarded so highly (at least over here) is Motul 300 range which I have never tried, due to the 'racing' reputation it has.
Regarding ball-wear tests, there might be more factors involved in engine situation because I have tried many others over the years and Shell had percievebly better overall performance.
Hence I'm asking about the whole subject.. Smile
PostPosted: Wed Sep 12, 2012 11:05 am Up
unless you got data to back up your statement otherwise i am not sure how you can say one oil is better than the other?
by looking at the formula it will perform no better than normal total 9000 or elf excellium 5w40; which is fairly low grade (cheap) oil.
PostPosted: Wed Sep 12, 2012 11:18 am Up
Even though I have access to a 205 litre barrel of Shell Helix Ultra Extra 5w30 oil I wont put any in my TU3 as it just looks to thin Confused
10w40 semi synthetic Total oil does my TU3 just fine.
PostPosted: Wed Sep 12, 2012 2:02 pm Up
Data no, experience yes.
I can categoricaly and with 100% confidence state that I have used Total 9000 (5W40), then put-in and compared with Helix Ultra (5W40) and the difference is astounding. One makes the car go like the clappers and burn less fuel (contradiction I know) whereas the former is just OK. This is taking into account long-term evaluation, adverse situations (v.high intake and ambient temps). I am aware that different oils have different specific viscosities at various temps even if they are quoted the same weight (eg 5W40). I am also taking into account the protection it affords to the engine, and the sound of the smooth pur it makes compared to a rougher noise after a 350 mile trip in the heat.
This is with two different TU3 206, and not just me either: www.psclub.gr/forum/vi....php?t=242
(125-page topic about engine oil in Peugeot cars, contains some simillar findings)
Helix Ultra 5W30 I have used for a while in the TU3 but I then decided it's too thin for summer use over here.
May well be perfect all year-round in the UK.
Gearbox (MA), on the other hand was a complete-nightmare on my 2001 206 until I put Total BV 75W80 and never looked-back.
PostPosted: Thu Sep 13, 2012 4:21 pm Up
human feeling compare to data....
as a scientist i trust data more.
PostPosted: Fri Sep 14, 2012 2:34 am Up
Smile
Agreed.
But as an engineer I want end-result.
Seriously, I make discussion exactly because I want to know more about it, and data always depends on exact application/conditions, no?
Many times physical outcome is totaly the opposite of what data would initially sugest, and scientists in all areas know this.
The aformentioned gearbox is a good example; it seems not only from me that even compared to all sorts of more expensive and better on paper oils in there (of the right spec), Total BV is the optimum for Peugeot box even though surely it's nothing special.
Sometimes I have found that the most expensive is not necessarily the best for a given application, and that excessive love 'kills'.
PostPosted: Fri Sep 14, 2012 2:55 am Up
People need to remember on here the TU engine & MA gearbox where born before a lot of forum members where even a glint in there daddys eye Laughing
TU lump first came out in 1986 fitted to the Citroen AX Laughing
PostPosted: Sat Sep 15, 2012 12:48 pm Up
Smile
Agreed.
you can quantified the end result too Wink
and don't get me wrong, i always use cheap oil Laughing
PostPosted: Sat Sep 15, 2012 1:34 pm Up
Seabook wrote:
Smile
Agreed.
Yes 'quantify' end-result is what I have tried to do with above posts.
Not data on paper and price tag.
You say use cheap oil (what is cheap, which one?) and what are your end-results from your experience?
PostPosted: Mon Sep 17, 2012 12:30 pm Up
i use to run torco 5w20 (35 quid 5L) in winter and i got the oil analysis done after oil change. nothing was flag up in the report.
No fuel dilution was detected nor coolant in oil.
PostPosted: Fri Sep 21, 2012 12:05 pm Up
OK.
You could try 5W30 Helix Ultra which is considerably more expensive but then we spend so much on the dreaded car in this forum.. Smile
It does go quite nicely after a while once it's broken-in though..
'Just my 2 drachma.
oilman
PostPosted: Thu Dec 05, 2013 11:47 am Up
Hi,
Until midnight Sunday we have a 20% SALE on our website with voucher code SALE20
If you need any oil advice then we are here to help! You can contact us here, alternatively give us a call on 01209 202944 Monday - Friday 8.30am to 5.30pm or send us an email to sales @ opieoils.co.uk
Cheers
Oilman
phone: 01209 202944
oilman
PostPosted: Tue Jan 14, 2014 5:46 am Up
Feel free to contact us here for any oil recommendations or any oil related questions you may have.
Alternatively complete our oil recommendation form and we will get back to you asap. You can also give us a call on 01209 202949 Monday - Friday 8.30am - 5.30pm or just drop us an email to sales @ opieoils.co.uk
Cheers
oilman
phone: 01209 202944
oilman
PostPosted: Tue Mar 25, 2014 9:31 am Up
Alternatively complete our oil recommendation form and we will get back to you asap. You can also give us a call on 01209 202949 Monday - Friday 8.30am - 5.30pm or just drop us an email to sales@opieoils.co.uk
Cheers
oilman
phone: 01209 202944
Page 2 of 3
