Online Now [524]:
Visitors: 524
Today: 49776
Total: 142432596
Forums › The Car › 206 Problems › VVT Solenoid
VVT Solenoid
LiamGTi180
PostPosted: Sun Dec 08, 2013 9:32 am Up
I've been meaning to clean the vvt solenoid for a while and finally got around to it. Got it out no trouble and gave it a good clean. When I put it back in I've rounded off the little Allen key screw that holds it in. Anyone know where I can get another one from? Will it be alright to run with the solenoid not in completely tight. Moves a few mm up. Thanks
PostPosted: Sun Dec 08, 2013 12:59 pm Up
Well you better replace the screw as soon as you can,and it can be found in any hardware store,you don't want the oil to be out while you drive if it's not tight enough,so better to done now.
LiamGTi180
PostPosted: Mon Dec 09, 2013 7:42 am Up
Any one know where in could get one from in the UK. Or a part no from Peugeot? Thanks
bashyy1
PostPosted: Tue Dec 10, 2013 11:31 am Up
Is there a guide on how to do this at all?
Aegean Blue Gti 180.
Project Thread
LiamGTi180
PostPosted: Tue Dec 10, 2013 11:51 am Up
No. This is how I did it.
Disconnect battery (follow proper procedure)
Removed the engine cover.
Took out the coil pack (makes it easier to access).
The VVT is situated just to the left of the coil pack.
Removed the little screw with a 5mm Allen key iirc and disconnected the solenoid. Removed the solenoid with mole grips (carefully).
Cleaned with carb cleaner.
Replaced parts in reverse order
PostPosted: Tue Dec 10, 2013 11:57 am Up
Look in your local Yellow Pages or 192.com. Find a nut and bolt or "fastenings" retailer - there must be quite a few in Oxford - take your car or just the bolt and they will match it.
PostPosted: Tue Dec 10, 2013 12:03 pm Up
Don't think it's too important at the moment
Clicky
LiamGTi180
PostPosted: Tue Dec 10, 2013 12:15 pm Up
Clicky
Guess where I was going when this happened Sad
bashyy1
PostPosted: Tue Dec 10, 2013 12:32 pm Up
Cheers for that mate, what exactly will cleaning it do, make it run smoother through the revs?
Project Thread
LiamGTi180
PostPosted: Tue Dec 10, 2013 12:37 pm Up
Yeah it will. My 180 was feeling a bit sluggish and didn't seem to pull as well as it used to. Took it out and cleaned it and it really made a difference. Pulls right up to the red line and so much smoother. Well it did anyway
bashyy1
PostPosted: Tue Dec 10, 2013 1:14 pm Up
Nice, will give it a go sometime
Project Thread
PostPosted: Fri Dec 13, 2013 12:33 pm Up
so did you bought the screw?if not,give your VIN number,and I can check if they sell the screw itself
