Latest: Worthy967
Overall: 17143
Online Now [555]:
Visitors: 554
Today: 39050
Total: 115229544
Forums › The Car › 206 Problems › 206 1.1 will not start
simi240
PostPosted: Sun Dec 01, 2013 12:25 pm Up
hi guys got a 1.1 206 and it wont start properly somtimes it will start and idle but if you try and rev it the engine bogs down and cuts out, the code it comes up with is p0412
PostPosted: Sun Dec 01, 2013 2:04 pm Up
Read this plz:
www.datsc.com/tabid/12...fault.aspx
simi240
PostPosted: Sun Dec 01, 2013 2:18 pm Up
whats the optical sensor
simi240
PostPosted: Sun Dec 01, 2013 7:11 pm Up
where is the air pump located i dont even think it has a air pump on it
simi240
PostPosted: Tue Dec 03, 2013 1:20 am Up
ok iv had a good look round there's no air pump from what i can see, whats the optical sensor ? its something iv not heard about before. it say in that link to check wiring but what wires sould i be checking for the optical sensor? iv looked on autodata and there's no info on there, could it be the ecu ? any help would be appreciated as i need to be back on the road asap.
PostPosted: Tue Dec 03, 2013 3:42 pm Up
sorry for late reply,the optical sensor is the sensor that monitors the movement of the timing belt (camshaft and crankshaft ),you will see it close to the crankshaft.
simi240
PostPosted: Tue Dec 03, 2013 4:18 pm Up
so im guessing that could be the crank sensor then or wiring to it or the timing could be out causing it or even the ecu then. i dont think there's a cam sensor fitted to the 1.1.
PostPosted: Fri Dec 06, 2013 2:43 am Up
send me your VIN to my inbox,and i can check it for you
simi240
PostPosted: Sun Dec 08, 2013 2:03 pm Up
don't have it at the minute but im sure its not got one fitted, anyway with the crank sensor plugged in the code p0412 comes on when trying to start it, remove the plug to the crank sensor and clear the codes, spin it over and no codes come back on. could it be the sensor or ecu or wiring. seems strange for it to not come up with crank sensor when its not plugged in.
PostPosted: Sun Dec 08, 2013 2:13 pm Up
well you can replace the crank sensor and try,but I would check the harness first.
simi240
PostPosted: Mon Dec 09, 2013 5:01 pm Up
ok I will give it a go
simi240
PostPosted: Tue Jan 28, 2014 1:17 pm Up
after much messing about with it iv decided to break it www.ebay.co.uk/itm/331...1558.l2649
