Online Now [180]:
Visitors: 179
Today: 14235
Total: 142920362
Forums › The Car › 206 Problems › What ECU do I have?
What ECU do I have?
robovw1303
PostPosted: Sun Dec 15, 2013 12:07 pm Up
I have 2.0 HDI 03 Quiksilver and i want to know if I have a Bosch or Siemens ECU.
The fuel rail is Bosch as the end part on the fuel rail.
I have found siemens in my fusebox and added a pic of my ecu.
Also the only markings on the fuel pump under the backseat are VDO which is referring to the sender unit.
I would like it to be Bosch so I can remap. Any ideas short of removing it?
206 HDI 2.0 Quiksilver
Full Stainless Decat
Stage 1 Tuned
PostPosted: Sun Dec 15, 2013 1:00 pm Up
You might be able to find out on servicebox in the characteristics section
robovw1303
PostPosted: Sun Dec 15, 2013 1:08 pm Up
I thought you had to be in the trade in order to register and view anything on there?
Stage 1 Tuned
PostPosted: Sun Dec 15, 2013 1:25 pm Up
You do.
robovw1303
PostPosted: Sun Dec 15, 2013 1:39 pm Up
Thought so, so anyone got any advice on seeing what ECU I have or do I have to take it out and see if there are any markings on the underside?
Stage 1 Tuned
PostPosted: Sun Dec 15, 2013 1:41 pm Up
Whats your vin? (only need the last Cool
I will have a look for you
robovw1303
PostPosted: Sun Dec 15, 2013 1:53 pm Up
Hmmm actually the EDC15 is Bosch right?
Last on the Vin is : 43393020
Could you tell me my paint code whilst your at it?
Thanks Smile
Stage 1 Tuned
PostPosted: Sun Dec 15, 2013 2:40 pm Up
EZR
Bosch
Any other info required?
robovw1303
PostPosted: Sun Dec 15, 2013 2:58 pm Up
Addaz wrote:
EZR
Bosch
Legend thanks!!!
Stage 1 Tuned
