Posted: Thu Dec 05, 2013 3:48 pm |
Yeh my reading skills (or attention span as some call it) are none exsistant tbh
| Team Impossible Possible
Posted: Thu Dec 05, 2013 4:00 pm |
Lol. You're forgiven. I never read the whole thing most if the time either.
Posted: Fri Dec 06, 2013 1:40 am |
RockRulz wrote: |
The new switch is on its way! My mechanic friend said he'd get it and fit it.....but I found out today he's off work with a bad back so cant do anything for the next few days at least. |
hope you got it fixed soon,as it's important for you,and other drivers too,wish I live closer,I would do it for you myself
Posted: Fri Dec 06, 2013 7:59 am |
Trade Rating: +59
Timon2210 wrote: |
RockRulz wrote: |
hope you got it fixed soon,as it's important for you,and other drivers too,wish I live closer,I would do it for you myself  |
You can fit it yourself if you have the right tools. Literally took me 5 minutes on my sister's 206, and that included removing the old switch. Pretty sure there is a guide on here too.
| '98 Nile Blue 306 GTi 6
'04 Obsidian Black 206 GTi 138 | |
Posted: Fri Dec 06, 2013 8:12 am |
Shut down the BSI, disconnect and remove battery.
Remove battery tray and air filter housing.
Disconnect the wire going to the switch.
Unscrew and remove switch and sealing washer.
Fit new switch and new sealing washer.
Reconnect wire.
Refit airbox, battery tray and battery.
Reconnect battery and reboot the BSI.
Check switch is working correctly
Posted: Fri Dec 06, 2013 9:53 am |
I don't have the new switch.
Mr mechanic has it ordered from his work
so as soon as he is back it will be done.
I agree I need it done urgently.
Posted: Fri Dec 06, 2013 11:36 am |
Timon2210 wrote: |
RockRulz wrote: |
I went for about 4 months without reverse lights. It's a nuisance at times... Would have to do a lot of parallel parking and cars would sit up my a**e as they wouldn't see the reverse light:\
Posted: Fri Dec 06, 2013 5:58 pm |
That's the one thing I'm worried about.....cars behind me bit knowing I'm reversing.
Posted: Fri Dec 06, 2013 6:10 pm |
Just put your hazards on and wait until they have gone round you
Posted: Fri Dec 06, 2013 6:48 pm |
macca1411 wrote: |
Just put your hazards on and wait until they have gone round you |
Didn't ever think of this, lol. I used to just be very lucky
Posted: Sun Dec 08, 2013 12:08 pm |
Lecktorious wrote: |
Timon2210 wrote: |
RockRulz wrote: |
You can fit it yourself if you have the right tools. Literally took me 5 minutes on my sister's 206, and that included removing the old switch. Pretty sure there is a guide on here too. |
I agree with you,I believe it's time to do a how to for this,do you think you can do it? since your sister still got her car.
Posted: Mon Dec 16, 2013 12:50 pm |
DSWR wrote: |
I tried to use lack of reverse light as an excuse too.. I replaced the switch the other day, you don't see the light at all when reversing! I reversed into a black fence a few weeks back..
Change your reversing bulbs.
It should be good enough to avoid hitting a fence!
Posted: Mon Dec 16, 2013 12:52 pm |
V9977 wrote: |
DSWR wrote: |
It should be good enough to avoid hitting a fence! |
They've got standards in, LED seem silly. It was a small black fence lower than the rear window, lol
Posted: Mon Dec 16, 2013 12:56 pm |
DSWR wrote: |
V9977 wrote: |
DSWR wrote: |
They've got standards in, LED seem silly. It was a small black fence lower than the rear window, lol |
Still.
