Online Now [316]:
Visitors: 316
Today: 46713
Total: 138566093
Forums › The Car › 206 Talk › few questions
few questions
commandosqueak
PostPosted: Mon Dec 16, 2013 2:07 pm Up
Had my pug for a while now, cheap to run as its a 1.4 HDI and has not let me down yet (touch wood). Seeing as the car is here to stay I want to do a few bits and bobs to it.
First things first, new rear axle, as the radius arm bearings are shot. I have the axle but are they a difficult job to swap? I'm guessing I would need new bearings when I pull the hubs off?
Once this is done I am going to lower it a little, about 30-40 mm max.
Completed a full service today, just need to change an injector as cylinder one is misfiring. Would it cause damage running on three cylinders?
Will put some alloys on, just to confirm PDC 4*108 and offset is 25-28 and the bore 65.1?
Cruise control is a no go and mine is a 200a3 which is a bummer Sad will upgrade to phase 2 headlights with HID's. Am I right in thinking I need pp2000 to alter the setting to twin bulb from single? And I also need an adapter loom?
With pp2000 what should I look for when buying, I have read loads of threads and know there are a lot of knock off's?
Finally I have a multiplexed 206 with ppt-40 two line display. If I wanted to upgrade to rt3 head unit etc is it a hard job? What bits do I need and are they available/ expensive?
A lot of questions I know but I am eternally grateful for any help Smile
2003 206 1.4 HDi (3 Door) LX - Cypress Green - KQM
2003 206 SW 2.0 HDI Grey
PostPosted: Mon Dec 16, 2013 2:21 pm Up
Why would you need new bearings when you take the hubs off?
commandosqueak
PostPosted: Mon Dec 16, 2013 2:25 pm Up
I haven't taken rear hubs off before but in my experience when taking front hubs off the bearing comes apart and normally needs replacing.
commandosqueak
PostPosted: Tue Dec 17, 2013 4:57 am Up
However i have now read my manual Embarassed and realised the bearings are designed to run the life of the car and shouldn't come apart when i take the hubs off.
Can anyone answer my other questions?
VorTechS
PostPosted: Tue Dec 17, 2013 5:10 am Up
Staff - Vortechs
You only need PP2000 if you want to switch from single optic to double optic (i.e. when using full beam, both bulbs are switched on at the same time).
Although given yours is 2003, I would have thought it would already do that? Everything should just be plug and play otherwise.
commandosqueak
PostPosted: Tue Dec 17, 2013 5:32 am Up
no mine does not do that, i have phase one lights. i am looking at swapping to either phase twos or halos but i know a lot of people dont like them
commandosqueak
PostPosted: Wed Dec 18, 2013 8:28 am Up
Can anyone answer any of my questions?
VorTechS
PostPosted: Wed Dec 18, 2013 9:29 am Up
Staff - Vortechs
Well Phase 1 to Phase 2 should be a straight swap.
commandosqueak
PostPosted: Wed Dec 18, 2013 12:15 pm Up
will i not need pp2000? i have the three pin plug taped behind which i found this morning when i checked the fluid levels so they should just plug in?
southwestchap
PostPosted: Fri Jan 03, 2014 10:37 am Up
to remove the axle, whip the hubs off, release the handbrake cables, then the brake lines, undo the mounting bolts
Soak in WD40 before fitting and clean up as best you can
Yes, sort that first!
not 100% but sounds about right
yes there is an option in pp2000 to set it as twin bulb setup, i've done this on mine
try to find a genuine person selling theirs if theyve moved away from Pug
Is that the MP3 oem headunit as in 307/207s etc? i've looked into this but no one actually seemed to of done it, so could be lucky of the draw if it works
commandosqueak
PostPosted: Fri Jan 03, 2014 4:05 pm Up
cheers mate you have been really helpful Smile
