Latest: Beduff1977
Overall: 17134
Online Now [566]:
Visitors: 565
Today: 20033
Total: 109476870
Forums › The Car › 206 Talk › How much are drive shafts?
DSWR
PostPosted: Tue Dec 17, 2013 1:01 pm Up
Hey, Everyone...
Well, this is awkward, haha.. Had a member complaining about drive shafts a few days ago, then a member telling me how the 17" vortex are too big and heavy for the 1.1's driveshafts.
I didn't really think much of it at the time, as I had done a reasonable amount of miles, but, yeah, driveshaft(s) have gone.. lol.
How much would you say drive shafts are each for a 1.1 with ABS etc? preferably new but a second hand price range would be nice too
GTi 180 owner!:)
www.facebook.com/notdanwhite
PostPosted: Tue Dec 17, 2013 1:10 pm Up
Depends on your build code. But between £214 and £284 new and £133 and £177 for a recon from dealers. Plus a £57 surcharge per shaft.
PostPosted: Tue Dec 17, 2013 2:09 pm Up
IF you're lucky you might find genuine new on eBay for quite low prices.
DSWR
PostPosted: Tue Dec 17, 2013 3:44 pm Up
Do you think they'd last a lot longer being new? if my 17" vortex's are what are actually knackering them, I would want them to last more than a few thousand miles
GTi 180 owner!:)
DanT
PostPosted: Tue Dec 17, 2013 4:02 pm Up
www.jandrcvjoints.co.uk/
Check those guys out, fair few people have used them with no complaints, i used to run a pair on my vts after a while and they never failed me. Good prices too.
Can't guarantee they'll be perfect with your wheel choice but there you go.
DSWR
PostPosted: Tue Dec 17, 2013 4:29 pm Up
Cheers, Dan:) will look into it. Having a friend come round tomorrow to check out my motor. It's only a minor knock at the moe at very low speeds, 4mph or so, so they've still got a week or two's life in them, haha.
GTi 180 owner!:)
iainlovatt
PostPosted: Wed Dec 18, 2013 3:09 am Up
Back in the day when i had a 1.1, i also did the same, In the end i went for 16" Nimrods, however i never fixed the issue, I also replaced the cv joins over changing the complete driveshafts.
If you want to fix the problem, you need to buy brand new from ECP, however dont forget that the there is labour on top which will be about £70.
Expensive job, just for the luxury of having 17" on a 1.1
(My Garage)
DSWR
PostPosted: Wed Dec 18, 2013 2:55 pm Up
I'll do all the work myself, it's just part pricing for me:) but it turns out it's not all bad, though! I originally thought the driveshaft had gone, but today I had time to actually get under the car and see what had actually happened, there is a bolt holding the bearing on the driveshaft that had came lose and the bearing was knocking... New bolt tomorrow and all should be good! That's what I'm hoping for anyhow! I am prepared for my driveshaft to go from running 17's, I knew they'd go in the long run anyhow when I first got them, I've done what I think has been 13,000 miles now, and they're still, somewhat (lol), working. I'd say the price to time range isn't as bad as it has been for others.
GTi 180 owner!:)
RoweY
PostPosted: Thu Dec 19, 2013 8:47 am Up
Does anyone know if this is the case for 1.4hdi's aswell ? do 17's vortex still knack up the driveshafts ?
DSWR
PostPosted: Thu Dec 19, 2013 8:50 pm Up
I'd say a 1.4 would be able to pull 17's.. Checked today, and my driveshafts are actually okay! a bolt had a knut come lose, and fell out! the bearing itself had been moving about making the noise... Fixed now! waheeey, cheapest repair EVER! haha:) I shall continue to lug on with my massive 17's!
GTi 180 owner!:)
PostPosted: Fri Dec 20, 2013 1:10 am Up
Good stuff..
pumba
PostPosted: Wed Jan 01, 2014 5:28 pm Up
hi which bolt came lose?? ill av a check of mine lol, mine makes a rattle type of knock at low speeds mines a 1.4 with 17`s
PUMB@206
