Latest: lio94
Overall: 17181
Online Now [146]:
Visitors: 145
Today: 29610
Total: 141896764
Forums › The Car › 206 Problems › HELP! Oil leak on GTi 180
cheekyage
PostPosted: Fri Dec 20, 2013 5:38 pm Up
Hi guys,
Can anyone tell me what engine component this is?
It's located right next to the cam belts and pulley.
I noticed a tiny drop of oil on my garage floor and then looked underneath to find a very small discharge around the black seal.
If anyone can pass on details as to what this is, why it's caused and how to fix it?
Smile
mattymj
PostPosted: Fri Dec 20, 2013 6:06 pm Up
Looks like the a/c pump. Maybe coming from above and dripping down
DanT
PostPosted: Sat Dec 21, 2013 2:43 am Up
Pics not the best but as above it could be coming from above so check that out if you can too. I had a slight oil leak when i first bought my 180 which looked like somewhere around the rear of the sump but upon closer inspection it was the rear cam cover and had just run down over time.
cheekyage
PostPosted: Sat Dec 21, 2013 7:55 am Up
Would the air conditioning pump/compressor leak oil? I didn't think that is a normal circumstance.
I'll take a closer look from above.
PostPosted: Sat Dec 21, 2013 8:38 am Up
The PAS pump is directly above the air con pump...could the oil have come from there?
