Latest: tbafonso
Overall: 17130
Online Now [168]:
Visitors: 167
Today: 27705
Total: 102550488
Forums › The Car › 206 Problems › 206gti 2nd fan/high speed
heyziq
PostPosted: Sat Dec 21, 2013 8:56 am Up
i did check with pps no fault,
but just now i went to some high hill road drive in second gear and 3rd gear and speed less than 60 km/h and temperature more than 90..nearly to 1 box before red and time taken to lower the temperature quite long.
after i add my speed then its reduce,
however now i realise when i switch my aircond the 2nd speed fan does not come in only low speed, is it something wrong?
check pps no fault
heyziq.com
PostPosted: Sat Dec 21, 2013 9:05 am Up
Air conditioning only runs the low speed fan.
heyziq
PostPosted: Sat Dec 21, 2013 9:12 am Up
ohh really? thank you for the info, actually i do not know why suddenly temperature raise up only when hill climb like that just flush coolant last week, maybe need re bleed..
heyziq.com
heyziq
PostPosted: Mon Dec 23, 2013 11:02 am Up
just check up just now, my radiator not working well Sad
heyziq.com
