Forums › The Car › 206 Problems › 206gti 2nd fan/high speed |
Posted: Sat Dec 21, 2013 9:56 am |
i did check with pps no fault,
but just now i went to some high hill road drive in second gear and 3rd gear and speed less than 60 km/h and temperature more than 90..nearly to 1 box before red and time taken to lower the temperature quite long.
after i add my speed then its reduce,
however now i realise when i switch my aircond the 2nd speed fan does not come in only low speed, is it something wrong?
check pps no fault
Posted: Sat Dec 21, 2013 10:05 am |
Air conditioning only runs the low speed fan.
Posted: Sat Dec 21, 2013 10:12 am |
Edward wrote: |
Air conditioning only runs the low speed fan. |
ohh really? thank you for the info, actually i do not know why suddenly temperature raise up only when hill climb like that just flush coolant last week, maybe need re bleed..
Posted: Mon Dec 23, 2013 12:02 pm |
just check up just now, my radiator not working well
