Latest: Beduff1977
Overall: 17134
Online Now [706]:
Visitors: 705
Today: 53526
Total: 108196363
Forums › The Car › 206 Problems › airbox....
airbox....
gizmothedog
PostPosted: Mon Dec 23, 2013 1:20 pm Up
I had a loose filter box at the weekend so I fixed it on sunday. I noticed whilst doing it how low the intake is....my eyes nearly popped out. my question is how can I make this higher? I looked at cone filters but I don't really want the induction noise (its a 1.4 with wheel trims...not really got the looks for that). with the heavy rain and deep puddles imminent I don't fancy an engine replacement.
any ideas?
Mr-Tigger
PostPosted: Mon Dec 23, 2013 1:26 pm Up
the air intake itself is inside the wing ABOVE the wheel. it should be sealed all way from the filter to there,if you have that bit missing then all you can do is replace/refit it or as you say,cone filter
gizmothedog
PostPosted: Mon Dec 23, 2013 1:30 pm Up
if I take the air filter out I can see straight to the floor...obviously an important bit missing. would a universal cone filter make it noisy or do you think it would be bearable?
lukepug19
PostPosted: Mon Dec 23, 2013 1:46 pm Up
depends in how heavy your right foot is to whether you think it is bearable but those universal ones can be quite noisey
234re
gizmothedog
PostPosted: Mon Dec 23, 2013 1:52 pm Up
don't think ill bother then. I would look a right tit..
PostPosted: Mon Dec 23, 2013 4:26 pm Up
In that case your resonator is missing.
It get's broken (it's a whole other tuned box) where it joins with the air box inlet at the bottom, and also some people take it off.
Get one from eBay; I did and it's quiet like a BMW.
www.ebay.co.uk/itm/206...3a844b6108
gizmothedog
PostPosted: Fri Dec 27, 2013 1:59 pm Up
Yeah thats it. If you look at the picture, its the one in the middle. The bottom of that is my final bit. Smile
