Online Now [1614]:
Visitors: 1613
Today: 173433
Total: 149243410
Forums › The Car › 206 Problems › Wing mirror
Wing mirror
Brokebad95
PostPosted: Tue Dec 24, 2013 7:47 am Up
Hi guys, I've had my first accident with my 206 :/ it's only minor but I reversed out of my mates drive in the dark and caught a bush which ripped off my O/S mirror. Tried to repair it but can't take it apart to connect the wires back up. Anyway, is there a difference between ph1 and ph2 electric mirrors? As I have to buy a replacement. Sorry if this is the wrong section but I couldn't find any other fitting.
Many thanks, Luke.
cartoonhead
PostPosted: Tue Dec 24, 2013 8:32 am Up
im sure there's 2 different plugs between the ph1 and ph2 , think one is white and one is brown but someone will be along that will know for certain
PostPosted: Tue Dec 24, 2013 3:45 pm Up
There is 2 diff. type of plugs,the white one for Pre-plexed model,and the black one for Multiplexed model,since yours is a preplexed as I can see from your signature,then you need the white plug,or replace the wire to match with the door loom,but both work fine.
