![](themes/base/images/spacer.gif) |
![](themes/base/images/titleTL.gif) |
Forums › The Car › 206 Problems › Bottom Air Condenser pipe |
![](themes/base/images/titleTR.gif) |
![](themes/base/images/titleBL.gif) |
![](themes/base/images/titleBR.gif) |
![](themes/base/images/forums/otl.gif) |
Posted: Mon Dec 30, 2013 4:28 am |
does this pipe go into a little bottle?
| | ![](images/spacer.gif) |
Posted: Mon Dec 30, 2013 10:10 am |
The drier? I think it does. There is also a sensor along the pipe too I recall.
Posted: Mon Dec 30, 2013 10:15 am |
These were all the bits from mine.
![](http://i38.photobucket.com/albums/e105/s1pso/SDC18938.jpg~original)
Posted: Thu Jan 02, 2014 3:06 am |
whats the one coming out of the bottom left hand corner of the condenser? thats the one that sheared
Posted: Thu Jan 02, 2014 6:07 am |
I got £1 for my condesner when I weighed it in at the scrap yard. Was nothing wrong with it either!
Posted: Thu Jan 02, 2014 7:24 am |
Okay, but what is the pipe at the bottom left hand corner of the condenser in the photo?
Posted: Thu Jan 02, 2014 9:38 am |
| 206 2ltr Hdi glx 53 plate | |
Posted: Thu Jan 02, 2014 10:21 am |
Hi thanks for that, but I couldn't get into that site.
I'm guessing thats the official pug part no?
Best regard
Posted: Thu Jan 02, 2014 10:23 am |
Posted: Thu Jan 02, 2014 10:28 am |
Is the DV6 ac condenser different?
Posted: Mon Jan 06, 2014 3:22 am |
This is my pipe that has snapped off the condenser
![](http://i72.photobucket.com/albums/i200/superredmr2/A5A6EF45-5320-49CD-919C-31F0C6B0F275_zpshnrhaewb.jpg~original)
![](http://i72.photobucket.com/albums/i200/superredmr2/C145E035-65BE-41D6-82F8-338A8261F360_zps8ebnukym.jpg~original)
Posted: Mon Jan 06, 2014 7:45 am |
This is the condenser I have, so I need the 11mm diameter hose for it
www.hypershop.org/car-...-8911.html
I've ordered the parts now.
Unfortunately the condenser on the DV6 is the only one on this model.
The pipe was £50.02 including VAT, just hoping it's not an absolute git to replace.
| ![](themes/base/images/forums/otr.gif) |
