Latest: Beduff1977
Overall: 17134
Online Now [435]:
Visitors: 434
Today: 238087
Total: 110092310
Forums › The Car › 206 Problems › Bottom Air Condenser pipe
206HdiGti
PostPosted: Mon Dec 30, 2013 5:28 am Up
does this pipe go into a little bottle?
PostPosted: Mon Dec 30, 2013 11:10 am Up
The drier? I think it does. There is also a sensor along the pipe too I recall.
PostPosted: Mon Dec 30, 2013 11:15 am Up
These were all the bits from mine.
206HdiGti
PostPosted: Thu Jan 02, 2014 4:06 am Up
whats the one coming out of the bottom left hand corner of the condenser? thats the one that sheared
PostPosted: Thu Jan 02, 2014 7:07 am Up
I got £1 for my condesner when I weighed it in at the scrap yard. Was nothing wrong with it either!
206HdiGti
PostPosted: Thu Jan 02, 2014 8:24 am Up
Okay, but what is the pipe at the bottom left hand corner of the condenser in the photo?
DREWDEN
PostPosted: Thu Jan 02, 2014 10:38 am Up
Its called a Airconditioned Freon Tube.
Part no 6460 JW
public.servicebox.peug...refaff=T1B
206 2ltr Hdi glx 53 plate
206HdiGti
PostPosted: Thu Jan 02, 2014 11:21 am Up
Hi thanks for that, but I couldn't get into that site.
I'm guessing thats the official pug part no?
Best regard
206HdiGti
PostPosted: Thu Jan 02, 2014 11:23 am Up
Is it this bit?
www.ebay.co.uk/itm/331...1431.l2649
206HdiGti
PostPosted: Thu Jan 02, 2014 11:28 am Up
Is the DV6 ac condenser different?
206HdiGti
PostPosted: Mon Jan 06, 2014 4:22 am Up
This is my pipe that has snapped off the condenser
206HdiGti
PostPosted: Mon Jan 06, 2014 8:45 am Up
This is the condenser I have, so I need the 11mm diameter hose for it
www.hypershop.org/car-...-8911.html
I've ordered the parts now.
Unfortunately the condenser on the DV6 is the only one on this model.
The pipe was £50.02 including VAT, just hoping it's not an absolute git to replace.
