Latest: Stu-mill
Overall: 17131
Online Now [374]:
Visitors: 374
Today: 13188
Total: 104698825
Forums › The Car › 206 Talk › Mud flaps on GTi 180
cheekyage
PostPosted: Fri Jan 03, 2014 7:18 am Up
Hi all,
Does anyone know if mud flaps were an optional extra or accessory on the GTi 180?
I've come across a car that has them fitted, they look factory and standard but not sure if they are genuine or after market.
Any further info or part details would be great.
PostPosted: Fri Jan 03, 2014 7:22 am Up
my 180 never came with the mudflaps and i'm sure none of them did but they available through peugeot and are very cheap, I did post a thread with the part no.s for the front/rear but not sure where on here lol
PostPosted: Fri Jan 03, 2014 7:25 am Up
found it Smile
www.206info.co.uk/Foru...flaps.html
Bigbenj_08
PostPosted: Fri Jan 03, 2014 7:31 am Up
Anyone know how to fit them?
I've got a pair of oem rears for sports bumpers but couldnt figure out how to get them on!
Aegean Blue 1.6 16v Sport
PostPosted: Fri Jan 03, 2014 8:00 am Up
you'll need to jack the rear of the car up and maybe even take the wheel off each side then they just screw to the inside facings of the bumper
Bigbenj_08
PostPosted: Fri Jan 03, 2014 11:26 am Up
Ahh that's what I thought... didnt fancy drilling into my bumper!
Lecktorious
PostPosted: Fri Jan 03, 2014 1:52 pm Up
Trade Rating: +59
Pretty sure it's just the arch liner, can't remember using any tools other than a screwdriver so it must have only been the soft plastic of the arch liner.
'98 Nile Blue 306 GTi 6
Bigbenj_08
PostPosted: Fri Jan 03, 2014 2:33 pm Up
Thats what I assumed it would be... but I couldnt figure out how to arrange the clips!
Maybe I'll have a coffee and try again!
PostPosted: Fri Jan 03, 2014 4:56 pm Up
You could be right, i never fitted the rears on mine, only the front
cheekyage
PostPosted: Sat Jan 04, 2014 12:32 am Up
These are only fitted on the front. Nothing at the rear.
PostPosted: Sat Jan 04, 2014 2:04 am Up
I have them fitted on the rear. There are a couple of U clamps which go around the lip of the bumper in the arch
and then this bracket underneath
Not sure if they are OEM or not as they were on when I got the car, but might give you some idea how they fit
PostPosted: Sat Jan 04, 2014 3:59 am Up
Fit them as intended to the front and as the tyres are wide the flaps do nothing. They need drilling and fitting further out.
