Online Now [61]:
Visitors: 60
Today: 52082
Total: 116788194
Forums › The Car › 206 Problems › 206 hdi wheel issue!
bunn7287
PostPosted: Fri Jan 03, 2014 2:34 pm Up
Hi all, I have a 1.4 Hdi which was fitted with 175/65 R14 alloy wheels/tyres. In order to prevent the bad front end wet weather grip, I have just fitted a set of Nimrod alloys off a 206 cc. These are 205/45 R16, which have a near identical diameter to the old ones, but are obviously lower profile and wider.
The wheels do not foul on anything at all etc, however when driving, especially at low speed there is a sort of grinding noise coming from the front!....... Can anyone suggest what the issue is, and a way of solving it?
Dave
PostPosted: Fri Jan 03, 2014 3:12 pm Up
have u fitted new tires on the Nimrods,or you used the old tires fitted on the wheels?
rlees85
PostPosted: Fri Jan 03, 2014 3:23 pm Up
Think you need to get it on a jack and turn each front wheel by hand to see if you can re-produce the noise... Sounds like a weird one to me.
Seatock789
PostPosted: Fri Jan 03, 2014 3:59 pm Up
I've just fitted 16" nimrods to mine but changed all the tyres at the same time so I don't have any strange noise's.
I've seen some of the threads on this forum and they've suggested that it could point to the wrong type of tyres, try swapping some of the wheels round and see if it makes a difference. Also check the tyres for stones inbetween the treads.
commandosqueak
PostPosted: Fri Jan 03, 2014 4:07 pm Up
its unlikely but check the bearings just in case. also have a look at the breaks to make sure as well,
2003 206 1.4 HDi (3 Door) LX - Cypress Green - KQM
2003 206 SW 2.0 HDI Grey
omega
PostPosted: Fri Jan 03, 2014 4:10 pm Up
have you fitted the right bolts for the wheels?
you have fitted wider wheels for better wet weather grip!!!!whos told you that?
you will be a lot better of with the narrow wheels.
1245678
bunn7287
Thanks for the replays,the wheels have good tyres on them, so haven't fitted new ones and I have jacked the fronts up and there is no noise when turned by hand and they spin freely...... I haven't had them balanced as yet, but there is no vibration only the rather disturbing noise?!
PostPosted: Fri Jan 03, 2014 5:08 pm Up
Brake disk heat shield rubbing on disk?
bunn7287
PostPosted: Sat Jan 04, 2014 4:34 pm Up
I have totally no idea what the issue is with these, but the noise is more than a little concerning! I have decided to chuck the old ones back on for the mo, and when I get the cambelt done in the next couple of weeks, the guy is going to have a look to see if he can sort it......
PostPosted: Sat Jan 04, 2014 4:54 pm Up
just new tires will fix it.
bunn7287
PostPosted: Sat Jan 04, 2014 7:28 pm Up
I can't see why the tyres would cause a grinding noise though to be honest, the noise is just like when brake pads have worn down to the metal (which is not the case)!
Tolkienfan001
PostPosted: Sun Jan 05, 2014 4:07 am Up
Trade Rating: +13
100% new tyres needed.
I bought second hand nims with tyres on. The tyres had loads of tread so left them on. I had a horrible noise at low speeds. Put four new tyres on. No more noise. One of the tyres was unevenly worn.
2005 1.4 16v Sport
Check out my 206 here!
Sim
PostPosted: Tue Jan 07, 2014 2:00 pm Up
Your nimrods+tyres are wider, they might start touching the strut/springs.
See if there are any scratches on the inside of your front wheels
Might not be caught while jacked up, because well, it's jacked up! Smile
PS: Tolkienfan001 watch out in case one of your new tyres gets eaten Wink
EV (roadtripper)
Jag S(crapped)- & X-Type
GTC VXR (sold)
