Online Now [366]:
Visitors: 365
Today: 59461
Total: 143368396
Forums › The Car › 206 Problems › Plastic connector
Plastic connector
Docbooze
PostPosted: Sun Jan 05, 2014 7:50 am Up
The 3 pin plastic connector that clips into the oil level sensor going into the sump (the one that flashes on the dash on start up) has snapped leaving just 2 pins and a loose wire. I know this is really just a gimmick and I would only ever go by the dipstick level anyway but would be nice to have it working especially when selling the car on.
Can you buy these as a replacement anywhere and just clip in the wires ?
Cheers
PostPosted: Sun Jan 05, 2014 8:11 am Up
I have one i could post to you for a couple of £ the sensor and i can snip the plug with a length of wire to attatch to your loom
PostPosted: Sun Jan 05, 2014 12:35 pm Up
Well the only way to fix this is,to have a new plug from dealer OR have one from Lee,with about 5 cm of wires,cut yours,and use a shrink tube with connectors and replace it,very easy job about 30 min. job if you wanna do it right,and slowly Smile
PostPosted: Sun Jan 05, 2014 1:09 pm Up
Soldering the wires is a better option.
Docbooze
PostPosted: Mon Jan 06, 2014 5:41 pm Up
Cheers. Spoke to a bloke a work today who has an old saxo he is scrapping. He said he'll have a look to see if he can see one that might be suitable before it goes to the scrappy in the sky !
