Latest: tebas93089
Overall: 17179
Online Now [155]:
Visitors: 154
Today: 14029
Total: 138432874
Forums › The Car › 206 Problems › 2002 206 1.1 ecu and bsi
ste4332
PostPosted: Tue Jan 07, 2014 10:35 am Up
Hi I have a 2002 206 1.1 and I have changed the ecu and bsi with one that has 58.000 miles on and my car had 62.000 miles on it but the problem is the mileage is showing 58.000 at first then changing to 119.000 miles anyone know why this is happening Thanks Ste
cartoonhead
PostPosted: Tue Jan 07, 2014 10:58 am Up
may be the seller lied and the car you got the ECU and bsi from had done 119K ?
ste4332
PostPosted: Tue Jan 07, 2014 11:31 am Up
No it does have 58.000 miles on it i did have someone try one on my car before I fitted this one I think that had higher mileage than my car had does this matter Thanks Ste
PostPosted: Tue Jan 07, 2014 12:08 pm Up
The mileage displayed will be from the highest BSI fitted, so if the one you plugged in to test had 119,000 on it, then that is what you're stuck with because it has also stored in the display, unless you get the BSI reprogrammed. Great for stopping the dodgy sellers clocking cars by just replacing the clocks for ones with lower mileage.
Lee once did a guide to changing the mileage but IIRC it wasn't a DIY job to do.
ste4332
PostPosted: Tue Jan 07, 2014 12:37 pm Up
If I change the clocks for the one that where on the other car will that change the mileage back or is 119k now locked in to the bsi and ecu Thanks Ste
ste4332
PostPosted: Tue Jan 07, 2014 3:19 pm Up
Anyone need to know ASAP Thanks Ste
PostPosted: Tue Jan 07, 2014 6:09 pm Up
Since yours is mux version 206 (multiplexed electrics, Oct.2001>) clocks make no difference and it's exactly as Macca says.
If it was non-mux (<Oct.2001) you could do the Lee trick and change the chip in the clocks etc.
It's quite a complicated job and requires soldering/desoldering of surface mount components, so specialist equipment is needed and experience with doing such 're-work' on boards etc.
'Hope that helps. Smile
ste4332
PostPosted: Tue Jan 07, 2014 6:39 pm Up
So is the mileage now stored in my new ecu and bsi Thanks Ste
PostPosted: Tue Jan 07, 2014 7:13 pm Up
The mileage is stored in the BSI and in the display. Not much you can do about it now. Thank your friend for giving you such a high mileage car.
One option you could do is find a lower mileage car the same spec as yours in a scrappy. Buy the BSI, ECU, immo chip and clocks and fit it all in yours.
PostPosted: Tue Jan 07, 2014 7:19 pm Up
It's irrelevant what the clocks say, it's the car's actual condition that matters.
DREWDEN
PostPosted: Wed Jan 08, 2014 11:26 am Up
Mileage correction companies can fix it £50ish Peugeot cannot, planet does not have the required software even dealers have to use mileage correction companies. Very Happy
206 2ltr Hdi glx 53 plate
ste4332
PostPosted: Wed Jan 08, 2014 6:29 pm Up
Hi is the 119k now stored in the new ecu?
Thanks Ste
commandosqueak
PostPosted: Wed Jan 08, 2014 6:43 pm Up
yes it is...
2003 206 1.4 HDi (3 Door) LX - Cypress Green - KQM
2003 206 SW 2.0 HDI Grey
