Latest: cogeim7
Overall: 17185
Online Now [537]:
Visitors: 536
Today: 226018
Total: 147124185
Forums › The Car › Solved 206 Problems › Replacing Water pipe on GTI 180
Forum Index › Solved 206 Problems
flyfour
PostPosted: Wed Jan 08, 2014 4:35 pm Up
Due to a split in the coolant pipe on my 206 GTI 180, I'm just checking to see if there is a certain way you removed the hose end that goes into the bottom of the radiator?
I've heard of nightmare issues concerning its removal and wondered if these were true?
Just really need to know that once the clip is removed, you basically carefully remove this hose end?
Thank you in advance for any helpful comments here Smile
PostPosted: Wed Jan 08, 2014 4:51 pm Up
You just referring to the long coolant hose into the radiator? Undo the clip and pull the hose off.
flyfour
PostPosted: Thu Jan 09, 2014 5:27 am Up
Hi Edward, yes it's the really long coolant hose that runs into the bottom of the radiator. Thanks for the advice.
