Online Now [112]:
Visitors: 111
Today: 18834
Total: 138698088
Forums › The Car › 206 Problems › Battery light coming on when driving
hamed206
PostPosted: Mon Jan 13, 2014 3:16 pm Up
I have noticed that during high speed the battery light is coming on and disappearing frequently. Is this an indication of alternator failure?
When checking the battery at normal car idle speed, the output voltage is 14V. The battery is also a new one.
Cheers.
Hamed
ukskater01
PostPosted: Mon Jan 13, 2014 3:32 pm Up
Have you checked your alternator
Cables, battery connections etc?
PostPosted: Mon Jan 13, 2014 3:38 pm Up
Is the belt squeezing?
hamed206
PostPosted: Mon Jan 13, 2014 4:41 pm Up
The negative battery cable was a little loose, I'm not sure if something like this may cause the battery light to come on while driving.
Hamed
hamed206
PostPosted: Mon Jan 13, 2014 4:42 pm Up
I will be so interested to check this point!
Hamed
PostPosted: Mon Jan 13, 2014 5:08 pm Up
You might have a problem with your AUX. Belt tensioner ,which cause the belt to be loose when speeding.
