Latest: S2cgm
Overall: 17178
Online Now [764]:
Visitors: 763
Today: 30010
Total: 137561196
Forums › The Car › 206 Problems › ABS Sensors?
ABS Sensors?
rdstars
PostPosted: Tue Jan 21, 2014 8:29 am Up
Hoping someone can help please. My 206 HDI 2.0 2002 multiplex rear Drum break is in need of new ABS sensors.
Phoned around today getting silly prices of up to £100 per pair. On ebay you can get a pair from just under £10 each but I cannot figure out which would be the right ones to buy.
Does anyone know the right part number for the ABS sensors or have a link to the right ones please.
Cheers
cartoonhead
PostPosted: Tue Jan 21, 2014 10:11 am Up
i have 2 eBay sensors on my car that i bought from >> HERE << and ive never had a problem and one was about 2 years ago , might be worth messaging them and asking which is the ones for your car
rdstars
PostPosted: Tue Jan 21, 2014 10:16 am Up
Hi,
Is yours a mulitiplex or preplex, drum or disc?
rdstars
PostPosted: Tue Jan 21, 2014 11:31 am Up
From ebay'ing, google'ing I can find two different type's so far,
02- 4545A0
-02 454579
But mine is an 02 so could be either, is there any way I could tell which one is right or needed.
cartoonhead
PostPosted: Tue Jan 21, 2014 12:41 pm Up
mines a pre-plexed and rear is converted to disk which is a whole load of fun when ordering anything for the back as the reg brings up drum Sad
PostPosted: Tue Jan 21, 2014 12:54 pm Up
02- 4545A0
-02 454579
You could check on servicebox using the last 8 of your VIN
rdstars
PostPosted: Tue Jan 21, 2014 1:16 pm Up
Cheers macca, just googled servicebox ( did not know what it was ) but it wont let me log in.
Just in case someone has an account for them and do not mind having a look my last 8 digits of my vin are: 42385649
Thankyou
PostPosted: Tue Jan 21, 2014 2:53 pm Up
Rear sensor is listed as 454579 £50.30
rdstars
PostPosted: Tue Jan 21, 2014 3:00 pm Up
Cheers macca, that should be the cheaper ones listed on ebay, about £20 for a pair.
Need the pair as both mine are seized and I know one is faulty, friend changing the rear axle for me for a reconditioned one from Axle Direct.
Is there a way of 100% checking them if I had the old ones in front of me?, do they look completely or noticeably different?
PostPosted: Tue Jan 21, 2014 6:08 pm Up
You need to use confirmed part numbers with these things..
rdstars
PostPosted: Wed Jan 22, 2014 3:58 am Up
Thats what I`m trying to do is confirm the part numbers.
From hours an hours of searchiing there only seems to be two different numbers from Peugeot, one being older than 2002 and the other being newer than 2002.
PostPosted: Wed Jan 22, 2014 4:24 am Up
I've given you the part number that should be fitted as standard to your car.
Here it is again in case you missed it
rdstars
PostPosted: Wed Jan 22, 2014 4:33 am Up
I did get it thanks macca, v9977 after was saying about using confirmed part numbers which is what we were both doing.
PostPosted: Wed Jan 22, 2014 5:53 am Up
Based on your VIN this is what Peugeot say is fitted
and this is the 4545A0 sensor which is since RPO 09457 , your RPO (build code) is 09264 so it confirms it's the earlier one
