Latest: airmastertapes
Overall: 17133
Online Now [551]:
Visitors: 550
Today: 30223
Total: 106742136
Forums › The Car › 206 Problems › My 206 1.4 2003 Model, engine temperature is low
azeem311
PostPosted: Wed Jan 22, 2014 9:48 am Up
In my peugeot 206 1.4 2003 Model, Petrol engine temp is 70'C when idle and while running 60'C or less. Could someone help to find the problem?
mtempsch
PostPosted: Wed Jan 22, 2014 11:39 am Up
Stuck open thermostat?
Start from cold and let it idle while monitoring the temperature of the hoses - should remain cool and then get warm/hot quickly when the thermostat opens. If stuck open,hoses will warm up gradually instead
Is temperature really low or is it just the reading?
Bad sensor giving low readings? Not sure how to check short of testing by replacement.
Maladjusted indicator needle? Does the 'parked / off' position look normal and not excessively low?
Silvermetallic 2004 206 RC
PostPosted: Wed Jan 22, 2014 12:22 pm Up
Well what mtempsch means that you got a dial looking like this:
www.206info.co.uk/Foru...52023.html
If that is the case,then follow the guide on how to fix it,and everything will be fine,BUT if that is not the case then....
You have a Stuck Open thermostat as he said,and it needs a replacement Smile
azeem311
PostPosted: Wed Jan 22, 2014 12:30 pm Up
Yes, I have started and kept in idle, the coolent line temp gradually increased, same time engine temperature is below 60'C.
azeem311
PostPosted: Wed Jan 22, 2014 12:40 pm Up
Timon2210, the needle is working fine and temp reach upto 70'C as maximum while driving and keep idle.
when I started to drive for five minutes, the temperature decreasing to less than 60'C rapidly.
mtempsch
PostPosted: Wed Jan 22, 2014 1:17 pm Up
Do you by "coolent line temp" mean the indicator in the instrument cluster or the hose?'
If the former, AFAIK the sensor sits 'on the inside' with respect to the thermostat, and the hoses are 'outside'. The indicator should rise smoothly as the engine block and the coolant in it warms up, but the temperature in the hoses 'outside' the thermostat should remain low until the termostat opens and then rise sharply. At that point in time the indicator might stop or even drop slightly as new cool coolant is brought into the engine as the flow through the system starts.
If the latter - time for a new thermostat.
PostPosted: Fri Jan 24, 2014 4:04 pm Up
Change the thermostat. Don't bother worrying or messing about with anything else. Refill coolant with long life coolant mixed to the correct quantity and ratio.
PostPosted: Sat Jan 25, 2014 2:19 pm Up
Then you need to replace the thermostat,and everything will be fine,I will post a How to guide in the next few days on how to replace the thermostat incase you don't know how to do this job.
Tolkienfan001
PostPosted: Sat Jan 25, 2014 2:24 pm Up
Trade Rating: +13
This would be a very good addition to the how to's Timmons. Smile
2005 1.4 16v Sport
Check out my 206 here!
