Latest: Stu-mill
Overall: 17131
Online Now [67]:
Visitors: 67
Today: 4949
Total: 104794426
Forums › The Car › 206 Problems › Dash and heater lights out
Franky
PostPosted: Sat Jan 25, 2014 2:35 pm Up
Can anyone help me at all all the lights have gone out in my dash heater controls and air con and demister switches
Connochio
PostPosted: Sat Jan 25, 2014 3:59 pm Up
I have one side of mine out, and it's driving me fricking crazy.
I reckon it's just the light inside has popped though.
PostPosted: Sat Jan 25, 2014 4:18 pm Up
Most likely the bulbs have gone. Any other lights not working?
Franky
PostPosted: Sat Jan 25, 2014 4:43 pm Up
Just the dash lights the heater lights and the two switches that control brightness and headlamp height are also out so is the cigarette lighter one
PostPosted: Sat Jan 25, 2014 5:29 pm Up
Fuse then more than likely.
PostPosted: Sun Jan 26, 2014 7:17 am Up
www.206info.co.uk/Foru...t=107.html
www.206info.co.uk/Foru...t=108.html
Franky
PostPosted: Sun Jan 26, 2014 8:06 am Up
Checked fuses all in tact so still can't find the issue
Franky
PostPosted: Sun Jan 26, 2014 10:11 am Up
Side lights out as well
DREWDEN
PostPosted: Sun Jan 26, 2014 10:48 am Up
Oh dear, i take from this yours is multiplex.
The cigarette light,(bulb) and the side lights run through the engine bsi through a resistor.
Are your number plate lights working.
Try a bsi reset, to see if this brings the lighting back.
Have you fiddled about with the electrics recrntly.
206 2ltr Hdi glx 53 plate
Franky
PostPosted: Sun Jan 26, 2014 12:25 pm Up
Cigarette lighter light is out to along with the dash and heater bulbs the air con and demister lights Buttons when pressed do not ulitimate either fitted new radio yesterday and now nothing works
PostPosted: Sun Jan 26, 2014 12:27 pm Up
You've def blown a fuse. Did you pull the fuse and and check it.
Franky
PostPosted: Fri Jan 31, 2014 12:26 pm Up
Hi all I have a 206 with a centre heater console that does not light up it works but the air con and rear heater lights do not light and there are no lights on it either,I have changed the whole lot and it still does not light up when I press the air con it works but no light when I then depress the rear screen switch it lights up the air con light? I cannot hear any click from the heater switch or anything any clues guys
PostPosted: Fri Jan 31, 2014 12:31 pm Up
Topic merged with your 51 plate 206 centre console not lighting up topic since it's the same problem. You could miss a solution by having more than one topic about the same fault.
Franky
PostPosted: Fri Jan 31, 2014 12:38 pm Up
Thanks macca
