Online Now [258]:
Visitors: 257
Today: 28535
Total: 138763807
Forums › The Car › 206 Problems › Newbie help
Newbie help
silvertwo-oh-six
PostPosted: Wed Jan 22, 2014 3:59 pm Up
Evening guys and girls,
Girlfriend bought a 206 1.1 LX on Sunday, and all seemed fine upon test drives, etc
We knew we'd need to get her at least 2 new tyres, no problem
She took the car to work, and when parking she felt crunching. This was when full lock or near full lock pulling away slowly.
Took it for a free check with a garage owner (who's also a family friend, conveniently)
O/S/R brake binding (both o/s wheels do not spin freely when in the air)
This is the major concern as its the one I have no knowledge of.
She needs new tyres, and new pads/discs. Which are no problem for me to sort out.
Brakes binding - bit of a search and a common issue, and hopefully the fix for our issue is the same as the one I read.
The white brake light switch/wire - located under the dash.
Apparently, first thing to try is taking the connection out and pu back in to make sure it's in the correct amount, etc.
As this uses the same bit as the actual brake pedal too.
So any ideas how exactly this fix is tried, as I can see A LOT of wires under the dash, and more than 1 being white...
Also any other suggestions on what it could be?
Thanks in advance!
Ben
RoaringMeg
PostPosted: Wed Jan 22, 2014 6:09 pm Up
The brake light switch is located through the hole in the mounting bracket shown here just above item 12
ww2.justanswer.com/upl...41_sss.jpg
Hope this helps Smile
silvertwo-oh-six
PostPosted: Thu Jan 23, 2014 2:57 am Up
Brilliant - that's made that a bit clearer. Thank you!
Will take a look ASAP.
Does anyone know other potential reasons for brake(s) binding?
commandosqueak
PostPosted: Thu Jan 23, 2014 5:13 am Up
dodgy calipers are always a popular one
2003 206 1.4 HDi (3 Door) LX - Cypress Green - KQM
2003 206 SW 2.0 HDI Grey
silvertwo-oh-six
PostPosted: Thu Jan 23, 2014 6:55 am Up
Thanks for the reply,
Is there a way to check if they are doing their job or anything?
commandosqueak
PostPosted: Thu Jan 23, 2014 7:12 am Up
go for a good run and use the brakes, if the caliper is hotter than the other side its binding. solution is new caliper or refurb kit. but that depends on how mechanically minded you are
silvertwo-oh-six
PostPosted: Thu Jan 23, 2014 7:22 am Up
Well I know the brake is binding. When jacked up both o/s wheels do not spin when pushed.
I will take for a drive and use brakes, and feel them to compare each side.
I try to do as much work as I can to my own car (not the 206) so hopefully with a few pointers that'd be a DIY job. I've had the front brakes off and replace discs and pads on a 1.1 saxo (so I assume probably a similar setup)
Thanks again
silvertwo-oh-six
PostPosted: Sat Jan 25, 2014 5:56 am Up
Issue has got worse.
O/S Front Brake/Wheel is ruled out as an issue
it's only the O/S Rear brake (drum)
Now when we try to pull away the o/s/r wheel just doesn't move. If I make the car move the wheel skids along.
I have had wheel off, and brake cleanered it, and sanded some rusted bits. More brake cleaner, left it for a while. Checked it, still stuck for good. I have hit it with a soft hammer (quite gently as I would rather not make another issue).. No change.
What can I do? Sad
PostPosted: Sat Jan 25, 2014 6:39 am Up
How did you clean the brakes if the drum is seized?
Try a lump hammer, the drum can take it.
A common problem on the drums is the friction material coming away from the shoe and jamming against the drum. Usually either rocking the car in forward or reverse gears frees it, but with a clunk. Then you can get the drum off and replace the shoes, lube up or replace the auto adjuster and it's sorted.
silvertwo-oh-six
PostPosted: Sat Jan 25, 2014 7:52 am Up
So the clunk that happened when I reversed is not too much of a bad thing?
I basically just cleaned what I could of all of it.
I dont have drums on my own car so have never looked at them
I will try lump hammer and the swaying now.. thanks! !
PostPosted: Sun Jan 26, 2014 4:27 am Up
It could be handbrake cable seized on one side. Not common on a 206 but does happen.
It could be the auto adjustment mechanism, retaining clips or spring holding the shoes in place have broken or dislodged.
As above it could be the brake material has separated from the backing.
You might have to use a lot of brute force to get the drum off as the drum probably has quite a ridge on the inside edge that won't clear the shoes.
It might be worth fully releasing the handbrake cable at he handbrake lever adjusting point. it wouldn't be the first time a handbrake was over tightened at this point.
The self adjusting mechanism inside the drum is complex if you haven't seen it before so buy a Haynes manual. Not perfect but helpful for jobs like this.
If you are removing the drums you will need new staked nuts and a torque spanner for refitting.
Behind the drum are a washer and seal - make sure you note the order and orientation these are fitted in. It is easy to get that wrong.
silvertwo-oh-six
PostPosted: Sat Feb 08, 2014 4:17 am Up
Thanks for a replies!
We now park the 206 in gear, with handbrake off. This has stopped the back brake seizing now.. obviously not a perfect scenario but its getting us out of trouble for a while.
The car seller bought us new brake shoes to say sorry to hear an issue occurred already.. ha!
Another issue: think I know the answer but..
When steering on full lock, so parking mainly.. the wheels sound like they are crunching.
I've done some searching and sounds like it could be the CV joint. How can I check? Am I looking for a leak or loose bits?
How much would a garage look to charge to replace 1 or both CV joints?
And how easy is it for DIY
Thanks again
macj
PostPosted: Sat Feb 08, 2014 6:12 am Up
CV joint it is..... get someone to listen to each side of the car as you turn tight each way. The suspect joint will show itself. Not the easiest of jobs if you are not very clued up on them. I suggest you get a garage to change the bad one. Should be about an hours labour
silvertwo-oh-six
PostPosted: Sat Feb 08, 2014 6:18 am Up
Cheers bud, will call for some quotes!
silvertwo-oh-six
PostPosted: Thu Feb 13, 2014 2:33 pm Up
The brake has been ok since we started parking without handbrake on.
Went to drive it yesterday and it was seized but unseized fairly easily to unseize.. but now it grinds.
Forward and reverse.
Has the shoe worn that much?
Or has it partially unseized?
