Latest: Kifi69
Overall: 17183
Online Now [521]:
Visitors: 520
Today: 26794
Total: 144318415
Forums › The Car › 206 Problems › MOT fail, what parts do i need?
TTnTT
PostPosted: Wed Feb 05, 2014 5:52 pm Up
Hey guys/girls,
Just had an MOt and my car has failed on 2 things
Just wondered if someone can clarify what i need to fix it and if i can do it myself
It failed on
"Nearside Track rod end ball joint has excessive play"
"Nearside front lower suspension arm has excessive play in a ball joint"
are these both the saem ball joint and roughly how much is it to get fixed? or is it something i can do myself?
Many thanks
cartoonhead
PostPosted: Wed Feb 05, 2014 6:02 pm Up
need's track rod end and wishbone on the passenger side , but make sure to get tracking done after its all been fitted Wink
PostPosted: Wed Feb 05, 2014 6:03 pm Up
If you've got the tools there pretty simple. new track rod end about a £10er from a motor factor, and a new bottom arm, prices vary depending upon how much you value a quality part.
if there on the same side shouldn't take you more than an hour and a half tops. But you will need to get the tracking checked afterwords.
TTnTT
PostPosted: Wed Feb 05, 2014 6:17 pm Up
Any rough prices on what garages charge?
Got quotes for £110-130 to fit the track rod end and lower suspension arm
cartoonhead
PostPosted: Wed Feb 05, 2014 7:08 pm Up
if they are supplying parts then chances are its going to be cheap track rod and wishbone from europarts ( probably £40 for parts ) so £70-£90 labor is steep seeing as it takes less than a hour to fit both parts Wink
TTnTT
PostPosted: Wed Feb 05, 2014 7:33 pm Up
Okay thanks a lot mate will get a few more quotes or look at doing it myself! Cool
206Info_SW_Scots
PostPosted: Sun Feb 09, 2014 9:01 am Up
Get a Garage Itemised qoute, then work out from there.
I had a 'front track rod end excessive play' and a 'rear trailing arm excessive play' fitted after a MOT failure at 100,000 miles.
206 SW 55 Plate - Happy Owner
PostPosted: Tue Feb 11, 2014 7:51 am Up
Get a "quote" not an "estimate." there is a very important difference. An estimate is exactly that - a knowledgeable guess at the cost. A quote is a firm price with cost of parts and labour properly checked and challengeable in a court of law. Lots of garages will "estimate" cheap to get the work then the parts turn out more expensive and the job will be "more difficult than expected." When that happens with an estimate there isn't anything you can do about it.
PostPosted: Tue Feb 11, 2014 8:34 am Up
Can you explain that to Ecosse in Scotland? They don't know the difference!
