Latest: jackrox1992
Overall: 17186
Online Now [373]:
Visitors: 372
Today: 26282
Total: 148565441
Forums › The Car › Solved 206 Problems › Break lights won't go off!!!
Forum Index › Solved 206 Problems
Sleeky
PostPosted: Mon Feb 10, 2014 2:34 pm Up
Hi Guys
I have a 1.4 206. On the way back from work, i was stopped by the popo and they told me that my break lights are faulty because you couldn't tell if i was breaking or not. So i came home and researched this problem and the first solution was the switch become loose or fallen out of its place.
So with tremendous effort, i removed the glovebox and realised that the sensor had snapped out of its place so i bought a new one and popped it in. so i start the engine and drive out of the driveway and my break lights are still staying on for some bloody reason!!
all lights are working and indicators are working. i recently changed my left headlight bulb and its a tad bit brighter than the one on the right but that was last month. The car was made in 2006. I would like to get back on the road as soon as possible because I have uni and work.
Any help will be greatly appreciated Smile
DREWDEN
PostPosted: Mon Feb 10, 2014 3:06 pm Up
Are your brake lights stopping on when you have all other lights turned off, (headlights and tail lights)
206 2ltr Hdi glx 53 plate
macj
PostPosted: Mon Feb 10, 2014 3:33 pm Up
Remove the new switch and manually depress the button to see if the lights go out. There is a possibility the switch was not installed correctly and has not made contact with the brake arm
Unplugging the switch should extinguish the lights.... if not you have a short in the system
PostPosted: Mon Feb 10, 2014 4:08 pm Up
I agree! What He Said
Sleeky
PostPosted: Tue Feb 11, 2014 8:46 am Up
depressed the switch and nothing happens. I unlpugged the switch and the lights still stay on Sad Is there anyting I can do to fix this?
also I found a green wire/connector unplugged but i dont know where it has disconnected from?? click 2nd link to see the green wire/connector
Heres a video of the process and whats happening (1st link)
www.youtube.com/watch?v=-Ye44XKHtEs
www.youtube.com/watch?v=xxJbHLkm3DQ
Sleeky
PostPosted: Tue Feb 11, 2014 8:50 am Up
If I have all the lights turned off and I brake the rear top break light comes on but the left and right break lights do not turn on. really hard to see when you have a spoiler but if I have all the lights on including headlight the break lights stay permanently on even without breaking.
If I do press the break the lights get 10% brighter but it is really hard to tell because they're already at 90%.
PostPosted: Tue Feb 11, 2014 9:53 am Up
Have you got the right bulbs in and are they in the right way round?
Sleeky
PostPosted: Tue Feb 11, 2014 10:39 am Up
The lights were fine before, the only light I changed was the front left (passenger) headlight which was last month but it was working fine. I only replaced the left side as it went out but didn't replace the right headlight as it was still working. The left headlight is 20% brighter than the right headlight.
I used 12v 55w Halfords Advanced high performance headlight bulb 477ULB H7 to replace the left headlight.
millow_99
PostPosted: Wed Feb 12, 2014 4:13 am Up
So thats why the pic in your banner has the 3 lights on?
Pug Lover!
Sleeky
PostPosted: Wed Feb 12, 2014 7:23 am Up
Yes lool thought while I had this problem, might as well update my banner Smile
Sleeky
PostPosted: Wed Feb 12, 2014 7:29 am Up
Can someone please tell me where the earth cables are so I can clean them.
DREWDEN
PostPosted: Wed Feb 12, 2014 11:44 am Up
Earth cables to check are behind both headlights, and one behind the rear LH tail light.
Seems odd that the top brake light should work with the lights off, and the left rear brake does not, as that works on the same circuit, (fuse).
Maybe worth trying a bsi reset after cleaning the earths.
Sleeky
PostPosted: Wed Feb 12, 2014 1:46 pm Up
Thanks, cleaned the earth cables and did a BSI reset but still no luck. I'm gonna have to take it a peugeot garage Sad
Sleeky
PostPosted: Thu Feb 13, 2014 2:38 pm Up
Got the lights fixed today. The problem was that Previous owner fitted a single filament bulbs in both rear brake lights which caused the problem. They needed to be double filament. Thank you everyone for your help. Greatly appreciated Smile
PostPosted: Fri Feb 14, 2014 1:59 am Up
Whistle...
