Online Now [573]:
Visitors: 572
Today: 33546
Total: 105075876
Forums › The Car › 206 Problems › Inconsistent Rear Tyre Wear
Bigbenj_08
PostPosted: Tue Feb 18, 2014 1:13 pm Up
I have abnormal wear on the inside edge of the offside rear wheel.
Its not consistent though. Ie, its not a band of wear which would indicate that the tyre was always at the wrong angle.
The only way I can describe it is as "wavy" up and down wear. There are no sharp edges, but a defined wave on the inside edge.
Now I've had the wheel bearings checked before and its just gone through its MOT and service (literally 10 days ago) and had no advisories on the rear suspension/bushings or the tyre.
However, I have had a hum, (SEE THREAD) which my mechanic has now checked 3 times, found nothing and can only seem to suggest its an issue with the tyre, however I have the same tyre on the other side and up front with no issues.
I'm lost. Any ideas?
I had a puncture today so had to buy a crappy tyre to get me home from north wales, so I'm tempted to swap the offside front and rear to see if I get the same wear on the cheapo tyre...
Aegean Blue 1.6 16v Sport
Targa180
PostPosted: Tue Feb 18, 2014 4:09 pm Up
I have the exact same on my Gti 180, have put it down to uneven front camber L and R (done purposely), sag in the rear shock bumpstops(they have become uneven) and typically because your sitting in the right hand seat you will corner right harder and faster meaning the rear pass side tyre cops more load.
Bigbenj_08
PostPosted: Tue Feb 18, 2014 4:25 pm Up
Cornering to the right? There is quite a few roundabouts on the way to work... could explain it I suppose!
Never had it before though which is the most confusing thing... Whats the cure, suspension overhaul?
Targa180
PostPosted: Tue Feb 18, 2014 5:01 pm Up
Talk to ppl in the know, suspension specialists. I have no plans to cure it on mine as its setup to go round a paperclip circuit IE all right hand bends.
