Online Now [343]:
Visitors: 342
Today: 43723
Total: 142312201
Forums › The Car › 206 Talk › Drivers Side Wing Indicator COVER fallen off
DSWR
PostPosted: Mon Feb 24, 2014 12:22 pm Up
Hey, guys. Basically the cover for the drivers side wing's indicator has fallen off when I was jet washing the car.. Just curious to how it goes back on, if at all? I can't tell if it was supposed to be a sealed unit that's glued up and you'd get the bulb out from behind the arch cover or something..
GTi 180 owner!:)
www.facebook.com/notdanwhite
PostPosted: Mon Feb 24, 2014 12:28 pm Up
Normally the front is sealed on. Depending on the year you either replace the bulb from behind as you say, or you buy one with an integrated bulb.
Probably a couple of pound from dealers or use the opportunity to upgrade them to some aftermarket ones
Edit. 3 listed on servicebox. Dearest is £6.62, but it would depend on if the original is clear or frosted lens
DSWR
PostPosted: Mon Feb 24, 2014 12:33 pm Up
It was a white frost:) I've still got the piece, I'll glue it on tomorrow:) Thanks, Macca!
GTi 180 owner!:)
PostPosted: Mon Feb 24, 2014 2:46 pm Up
By 2 new clear ones,looks smarter Very Happy
DSWR
PostPosted: Tue Feb 25, 2014 4:58 pm Up
Fixed! heat gun, wheyy! and I like the frosted ones as you can't see the orange bulb inside:)
GTi 180 owner!:)
