Posted: Tue Feb 25, 2014 7:53 am |
AGH!!! ok my 206 is currently in the peugeot garage had a faulty airbag light....however they have informed me that there is a tiny leak on the head gasket which will cost me £800 on top of the £500 for the other work the car runs fine but has always hated traffic jams ive had it for 3 years now.... im asking for advice is the price likely to be cheaper else where or should i risk it til it actually goes...its 06 plate and only done 56k...i was thinking of selling it before it went into the garage and not planning on spending £1300!!!
Posted: Tue Feb 25, 2014 10:40 am |
Put it this way. I had an mg zr before i bought my gti and that was £350 with a mobile mechanic (but done it myself for £50), I HIGHLY doubt doing it on a 206 would be any different. I think they are taking the p**s at that price mate
Posted: Tue Feb 25, 2014 11:20 am |
thank you so much for your rely i know they can be dearer than most garages but i have had some really bad "repairs" done previously at my local ones which have ended up costing more..but i wont be paying peugeot for this one lol
cheers
Posted: Tue Feb 25, 2014 12:26 pm |
There are loads of decent independent garages out there. Peugeot dealers don't make sense for any car that's under warranty still.
Posted: Tue Feb 25, 2014 12:29 pm |
It will be a headgasket oil leak. Its very very common, and I wouldnt worry about it if I was you
| Team Impossible Possible
Posted: Tue Feb 25, 2014 1:32 pm |
thanks all....the service guy checked value and he thinks between 2-2.5k so it cant be too bad ;-!
Posted: Wed Feb 26, 2014 2:57 am |
8ton for a head gasket? did you get free lube for when they bummed you
Posted: Thu Feb 27, 2014 2:16 pm |
I would try a bottle of "steelseal" first.
My dad used it in a golf and it worked.
£30 with a money back guarantee?
