Posted: Mon Feb 10, 2014 2:42 pm |
the front work well when you select front, but when you do the rear it also comes out of one of the front ones (not with much pressure on the front screen when it happens) other than that the back works ok lol.
any ideas why this happens?
ben
Posted: Thu Mar 06, 2014 12:01 pm |
Bump
Posted: Thu Mar 06, 2014 12:05 pm |
Possible BSI or Comm 2000 fault.
Posted: Thu Mar 06, 2014 1:54 pm |
macca1411 wrote: |
Possible BSI or Comm 2000 fault. |
Does the 206 use the system with one pump that gets forward or reverse voltage to shoot water out one of two different outlets depending on how the voltage is applied (and which direction it spins)? If so it could be mechanical issue in the outlet part of the pump.
As to rear not dribbling when front is applied could be due to the longer line offering more resistance (and travel distance/time).
| Silvermetallic 2004 206 RC | |
