Latest: airmastertapes
Overall: 17133
Online Now [105]:
Visitors: 104
Today: 100742
Total: 106812568
Forums › The Car › 206 Problems › screen washer does front and back at same time.....
PostPosted: Mon Feb 10, 2014 2:42 pm Up
the front work well when you select front, but when you do the rear it also comes out of one of the front ones (not with much pressure on the front screen when it happens) other than that the back works ok lol.
any ideas why this happens?
ben Very Happy
PostPosted: Thu Mar 06, 2014 12:01 pm Up
Bump Wink
PostPosted: Thu Mar 06, 2014 12:05 pm Up
Possible BSI or Comm 2000 fault.
mtempsch
PostPosted: Thu Mar 06, 2014 1:54 pm Up
Does the 206 use the system with one pump that gets forward or reverse voltage to shoot water out one of two different outlets depending on how the voltage is applied (and which direction it spins)? If so it could be mechanical issue in the outlet part of the pump.
As to rear not dribbling when front is applied could be due to the longer line offering more resistance (and travel distance/time).
Silvermetallic 2004 206 RC
